Postprocessor encryption according to EU
support308
support308
Hi everybody,
I have a question regarding EU Postprocessor Encryption. I want to lock my Postprocessor according to the customer's EU code. How can I do it?
Thanks and best regards,
Tuan Nguyen
boopathi.sivakumar
If you are using the fusion post processor utility vs code utility then there is a option to encrypt your post's
If the addin is installed then you can press F1 > encrypt then you type the password the encrypted post will be saved in the same directory as the original post
same way you can decrypt the post as well by doing  F1 > decrypt
Boopathi Sivakumar
Senior Technology Consultant
support308
Hi Boopathi,
I read about this encoding in the docs, but it can only be encoded so that the postprocessor can't copy it, but they are still used with many different EUs.
I am looking to encrypt just one EU purchase account that can be used. Avoid the case where different EUs use the same Post and can copy each other for use.
I don't know if Fusion currently supports that feature.
Tuan Nguyen
