Post zminimum comment for each operation? <Solved>
dgibbsEYJNH
dgibbsEYJNH
I have been trying to add Zmin for each operation not just a zmin overall.
xyzFormat.format(zRanges[tool.number].getMinimum()
Is there something like the above I can add to make it display comment under each operation or even at the top is fine.
My internal pockets often go below the height of my jaws I would like to be able to quickly check that the minZ for my profile ops are not going hit my jaws.
Thanks!
dgibbsEYJNH
I solved it, in case anyone else needs it this is what I found.
Under the 2nd section "(hasParameter("operation-comment")) {"
Changed below code added 2 lines. The ones with comments are only ones I added.
if (hasParameter("operation-comment")) {
var comment = getParameter("operation-comment");
if (comment && ((comment !== lastOperationComment) || !patternIsActive || insertToolCall)) {
writeln("");
writeComment(comment);
lastOperationComment = comment;
var zRange = currentSection.getGlobalZRange(); // added this line
writeComment(localize("ZMIN") + "=" + xyzFormat.format(zRange.getMinimum())); //and this line
} else if (!patternIsActive || insertToolCall) {
writeln("");
} else {
writeln("");
