Post with Absolute I and J
I have a 2D mill, (no Z) with an older Centroid controller.
It requires the I & J values to be absolute not incremental.
I can deal with manually removing all the Z code and inserting pauses for raising/lowering the Z axis.
Is there a post included with HSMXpress that provides absolute I & J values?
Is it as simple as changing this code in the .cps file?
// circular output
var iOutput = createReferenceVariable({prefix:"I", force:true}, xyzFormat);
var jOutput = createReferenceVariable({prefix:"J", force:true}, xyzFormat);
var kOutput = createReferenceVariable({prefix:"K", force:true}, xyzFormat);
What do I change it to?
Thanks for any help
fonsecr
The generic HURCO post uses absolute arc centers so the code has to look the same.
var iOutput = createVariable({prefix:"I", force:true}, xyzFormat);
var jOutput = createVariable({prefix:"J", force:true}, xyzFormat);
var kOutput = createVariable({prefix:"K", force:true}, xyzFormat);
In onCircular() you need to use:
iOutput.format(cx)
jOutput.format(cy)
kOutput.format(cz)
Instead of:
iOutput.format(cx - start.x, 0)
jOutput.format(cy - start.y, 0)
kOutput.format(cz - start.z, 0)
René Fonseca
Software Architect
I would like to try this option (absolute) at HEIDENHAIN. We found the code to:
http://forum.hsmworks.com/index.php?topic=7.0, but the code is more than a year old.
It is thus still relevant or need to be adjusted differently?
It would be possible to add HEIDENHAIN switch, similar to fanuc incremental.cps http://forum.hsmworks.com/index.php?topic=96.0?
fonsecr
This forum post is not about absolute versus incremental coordinates. Maybe this needs to go in a separate post. Heidenhain doesn't use an equivalent for G90/G91.
René Fonseca
Software Architect
Rene, thanks so much for your help.
I got it to work by leaving the //circular output as:
and changing the onCircular() references to:
iOutput.format(cx,0)
jOutput.format(cy,0)
kOutput.format(cz,0)
This outputs X, Y and I, J as absolute. Hooray!
While I have your attention, do you have any posts that are 2D only, (no z references)?
fonsecr
Not a Centroid one.
In onOpen() add:
zOutput.disable();
This will take care of most Z output. Next look for any additional "Z" references and comment them out (e.g. machine retracts).
René Fonseca
Software Architect
scottmoyse
I got it to work by changing the onCircular() references to:
Legend! Thanks. I was staring at those values wondering if that was the difference between incremental and absolute, but not really understanding the math. This is spot on. Cheers.
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
