Post processor NK260
Hello, I have a Chinese CNC router with ATC and Weihong NK260 controller
I am using Fusion 360 and looking for a post processor
I received a post processor for Artcam from the manufacturer, the file is attached
dillon.moulder
Hi @Anonymous,
Welcome to the Autodesk Community and the HSM Post Processor Forum.
You can find the Post Library for Fusion 360 and Autodesk HSM here.
The Superstarcnc.con file attached to your post is incompatible with Fusion 360 and Autodesk HSM; it can only be used with ArtCAM software.
You might find this discussion useful.
Kind regards,
Hello
The attached file is for reference, this is the Autocad post prossesor that
the manufacture sent me
It seems like the NK260 post prossesor is based on NC Studio, which post
should I use?
dillon.moulder
Hi @Anonymous,
@Anonymous wrote:
The attached file is for reference, this is the Autocad post prossesor that the manufacturer sent me
It seems like the NK260 post prossesor is based on NC Studio, which post should I use?
Please try using the 10717_Weihong NCstudio_with arcs.cps post processor attached to this post by @skidsolo. You might find this topic useful, as it explains where to install *.cps files.
Otherwise, perhaps @hai.cao or @jeff.walters can assist you here, as they seem to have provided a post processor to a customer with a Weihong machine in this topic, albeit some time ago.
If you have any further questions, please do not hesitate to ask. Otherwise, please be so kind as to accept my response as a solution. Thanks in advance for your time and cooperation.
Kind regards,
