post processor for Siemens 840SL with B & C 5 axis Spinner u1530 machine
workshopB26JU
workshopB26JU
Recently moved over to Fusion 360  and need to sort out our post processor for a SPINNER U1530 5 axis with SINUMERIK SIEMENS 840SL control
We've cam'd up a simple part that requires some B and C axis moves, but when we try to post using the generic post downloaded from fusion with some minor home settings tweaks, but we get an error which looks like it relates to the B and C axis settings ...
Our machine a  SPINNER 5 axis has a  B and C axis configuration rather than a B & A axis
can anyone point us in the right direction on how to set the correct B & C configurations
fusion post errorfusion post errorspinner machine configurationspinner machine configuration
i'm guessing this would be done in the part of the post below ???
return options;
function onOpen() {
if (false) {
var aAxis = createAxis({coordinate:0, table:true, axis:[1, 0, 0], range:[-120.0001, 120.0001], preference:1});
//var bAxis = createAxis({coordinate:1, table:true, axis:[0, 1, 0], range:[-120.0001, 120.0001], preference:1});
var cAxis = createAxis({coordinate:2, table:true, axis:[0, 0, 1], range:[0, 360], cyclic:true});
machineConfiguration = new MachineConfiguration(aAxis, cAxis);
setMachineConfiguration(machineConfiguration);
optimizeMachineAngles2(0);
Many Thanks
Martin
Marek_Skotak
 by a error you are trying set multiple Zero point (more then one Setup like  G54, G55, G56 .. ). Try it with with set up one Zero point and tilt set by a Tool direction in a operation.
Then output will be for Sinumeril like Cycle 800 (...... ) for create new local workplane on a machine.
About a kinematics machine set up .
Yes it is on this place like you are writing.
//var aAxis = createAxis({coordinate:0, table:true, axis:[1, 0, 0], range:[-120.0001, 120.0001], preference:1});
Postprocessor writer, CNC trainer, .NET programmer, www.cadcam-softcz.cz
teknikHQ28G
I have a Spinner u630 5-axis machine. It has a SINUMERIK SIEMENS 840SL control unit.
Could you share if you are actively using a post processor?
