Post processor for DMG MORI DMU 75
quintinoFJ499
quintinoFJ499
Good Day
I am in search of a Post Processor for the DMU 75 Monoblock with the Siemens Celos control.
I have tried using and manipulating the NHX Celos control post found in the Fusion library bu with no successs
Anyone able to shed some light?
AdamKunzo
CELOS is not a CNC control system but only a user interface (HMI) developed by DMG MORI. The actual CNC control on your machine will likely be Siemens Sinumerik 840D (or its newer version, 840D sl).
I would recommend checking which version of the control system is installed on your machine and then selecting the appropriate postprocessor accordingly. The postprocessor should generate NC code compatible with your machine.
However, for multi-axis machining, it will be necessary to define a proper machine configuration or modify the postprocessor.
If you need assistance with this, feel free to contact me. I offer postprocessor customization as a service and would be happy to help you with it.
If my response answers your question, please use Accept Solution button.
quintinoFJ499
Good Day Adam
Thank you for the clarification.
That helps a ton!
will investigate the 2 post proccessors and be in contact please feel free to contact me via email to discuss solutions for your help.
Kind Regards Quintin
