Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Post Pro DMU50 evol year 2000 with TNC 426 heidenhain
olivier_quetier
Message 1 of 10
olivier_quetier
I am looking for a pro post for a DM50 evolving year 2000 equipped with a 426 - 430 Heidenhain drive. Knowing that the downloadable pro-version 426 of Heidenhain does not work on the rotation control of axes B and C.
Thank you
Olivier Quétier
Replies (9)
Message 2 of 10
Laurens-3DTechDraw
The 426 post processor does work, you just have to set it up correctly.
Read about that here: https://forums.autodesk.com/t5/hsm-post-processor-forum/how-to-set-up-a-4-5-axis-machine-configurati...
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
Message 3 of 10
olivier_quetier
Bonjour,
J'ai bien lu le forum, mais dans le post-porcesseur heidenhain 426, je ne trouve pas l'étape 5 et la ligne "optimizeMachineAngles2(1); // TCP disabled", je ne sais pas quoi modifier.
Merci.
Olivier Quétier
Step 5:
optimizeMachineAngles2(0); // TCP enabled (eg. M128, TRAORI, G43.4, G243)
optimizeMachineAngles2(1); // TCP disabled (eg. M128, TRAORI, G43.4, G243)
  • With this option you can decide if your machine has TCP capabilities for 5 axis simultaneous machining or not.
Message 4 of 10
Laurens-3DTechDraw
It's this line: optimizeMachineAngles2(0); // using M128 mode
Laurens Wijnschenk
3DTechDraw
Message 5 of 10
olivier_quetier
Bonjour,
J'ai bien la ligne indiquée et le post pro ne fonctionne pas en 5 axes simultanés (fonction swarf). Je ne comprends pas le problème.
En pièce jointe le post pro, le message d'erreur et une photo de la pièce test.
Merci encore pour votre aide.
Olivier Quétier
Message 6 of 10
Laurens-3DTechDraw
Have you tested if the 3+2 movements work correctly?
Laurens Wijnschenk
3DTechDraw
Message 7 of 10
olivier_quetier
Oui, les 5 mouvements fonctionnent.
C'est le post-pro qui ne génère pas le code. C'est la que se trouve le problème.
Message 8 of 10
Laurens-3DTechDraw
The problem you have now is a safety feature.
But before we try to solve that.
Does the 3+2 work? (https://www.youtube.com/watch?v=VgwctDi3ZPA)
So does the rotation of the axis when just doing 3 axis milling work correctly on the machine?
If that is tested we can help solve the 5-axis simultaneous issue.
Laurens Wijnschenk
3DTechDraw
Message 9 of 10
olivier_quetier
Bonjour,
Oui, j'ai tester tout ces éléments, le problème c'est l'écriture du programme par le post pro pour les fonctions swarf et multi-axis contour.
Merci
Olivier
Message 10 of 10
olivier_quetier
Bonjour,
Avez vous pu regarder mon problème, car je n'ai toujours pas trouvé la solution.
Merci.
Olivier Quétier
Have you been able to watch my problem because I still have not found the solution.
Thank you.
Olivier Quetier
