Solved by 150521. Go to Solution.
I had a quick read of the reference handbookl, and saw that this could be programmed with our generic RS274 post processor. this is installed with the software.
I made and tested a beta post for Beamicon2. You can help to test it, please use caution. There is a user property when posting for the Z retract height thats default to 20 mm.
Here is a screen shot of my test:
I revised the retract to use G53 Z0. Think according to the documentation G43 is valid for tool length compensation. I sent this post to the developer also.
@Anonymous wrote:
I don't know why my postings lose their formatting. And I don't see my attached nc file in my previous posting furthermore. Search, options and other funtionalities seem to be disabled. So don't wonder about my strange postings...
Are you replying by e-mail? Or on the forum?
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
When I tested this on the software in demo mode, I found you do need the G0 with the G53.
Yes I worked with Nicolas benezan. here is the last email he sent me.
we have tested the postprocessor and have found no problem. So I think
we can publish it.
Just one minor issue: One of our customers has sent us a program. I
think he used a PP version he has created on his own. It contained lines
like this:
N870 X35.524 Y278.295
N875 X35.069 Y272.897 (several mm per segment, small angles)
N880 X35.068 Y272.891
N885 X34.147 Y262.36 (and now...)
N890 X34.146 Y262.357 (... only 3µm, rounding error -> 15° angle)
N895 X33.239 Y252.124
N900 X32.801 Y247.099
N905 X32.379 Y242.121
The tiny line segments with less than 10µm length results in rounding
errors so that the software thinks that there is a sharp bend. If a
certain threshold is reached the software inserts a
deceleration/acceleration ramp which slows down the machining process
and causes unwanted jerks even if the rest of the toolpath curve is very
smooth.
I think this should not happen with the current PP version as it has
minimumChordLength = spatial(0.01, MM);
in it. But just to be sure I changed the precision of the XYZ output to
four decimals:
var xyzFormat = createFormat({decimals:4});
Additionally I changed the Beamicon2 software to ignore very short lines
that are much shorter than the toolpath tolerance.
Best regards
Nicolas Benezan
Benezan Electronics, Mötzinger Str. 11, D-72108 Rottenburg Baisingen
CNC- und Steuerungstechnik, Elektronikentwicklung
