Been trying to figure out how to change when doing a part off operation to be able to use exit feed speed and not cutting feed speed.
Solved by ivan.stanojevic. Go to Solution.
gdaniel450
Could you give an example of what the code would look like. For example are you wanting to feed in and then retract out at a different feed rate?
Here is what I mean
(TURNING PART1)
N14 T0909
N15 G54
N16 M8
N17 G99
N18 G97 S1500 M3
N19 G0 X2.6 Z0.
N20 G0 Z-1.631
N21 X1.8
N22 G1 X-0.063 F0.003
N23 X1.8 (right here it is retracting at F.003 Wish it would switching to the retracted speed of F.1 for what I programmed at)
N24 G0 X2.6
N25 Z0.
N26 M9
N27 G53 X0. Z0.
N28 M30
This is a known issue which has been discussed almost 2 years ago..
Parting operation simply doesn't have rapid moves which will allow different feed on retract, and this issue needs to be fixed.
You can vote for the idea here:
https://forums.autodesk.com/t5/hsm-ideas/rapid-out-after-cutoff-turning/idi-p/6503830
Nevertheless, this idea has been accepted and I hope that it will be implemented soon.
Ivan Stanojevic
