Okuma coolant off / dwell
Hi everyone.
I'm looking for help modifying my post. Currently, at the end of an operation, the spindle turns off, then it rapids up, then the coolant turns off. I would like to change the order of things so that first the coolant turns off, then add a dwell (2 seconds?) for the tool to spin off excess coolant, then the rapid and everything else as it is now.
I have rudimentary coding skills so i was able to figure out how to change all the m06 with g116 for the okuma, and I was able to make the end of the program do a G30 Px before the M02. The order of operations mentioned above is a little outside my wheelhouse. Any ideas?? thanks
Chris
bob.schultz
Hello Chris,
This is a pretty simple change.  I am guessing that you are using the stock Okuma post, so the changes I am suggesting are based on this post.
First find this code in the onSection function.
  if (insertToolCall || newWorkOffset || newWorkPlane) {
    // stop spindle before retract during tool change
    if (insertToolCall && !isFirstSection()) {
      onCommand(COMMAND_STOP_SPINDLE);
    // retract to safe plane
    writeRetract(Z);
    if (newWorkPlane) {
      setWorkPlane(new Vector(0, 0, 0)); // reset working plane
And modify it to look like this ...
setCoolant(COOLANT_OFF); // add these 2 lines
onDwell(2);
// retract to safe plane (move these 2 lines up)
writeRetract(Z);
// stop spindle before retract during tool change if (insertToolCall && !isFirstSection()) { onCommand(COMMAND_STOP_SPINDLE); } if (newWorkPlane) { setWorkPlane(new Vector(0, 0, 0)); // reset working plane } }
Now comment out the coolant off code further down the function.
  if (insertToolCall) {
    forceWorkPlane();
    // setCoolant(COOLANT_OFF); // comment out this line
    if (!isFirstSection() && properties.optionalStop) {
      onCommand(COMMAND_OPTIONAL_STOP);
Bob Schultz
Sr. Post Processor Developer
