Okuma 560V-5AX P300 tool changer modification
info
Message 1 of 9
info
I need some advice on how to modify the m6 code on the tool changer with G116.
Please find my post processor attached.
Replies (8)
Message 2 of 9
RohitMane_
Hello @info ,
Just curious, Have you tried enabling the post property called “Enable Safe Tool Change Logic”? This property allows the post to check whether the tool being called is already loaded or staged.
Message 3 of 9
info
Hello @RohitMane_
Yes, I've already tested it, but in my G116 I have protected connections and the tool length corrector is already active immediately after the tool change.
Message 4 of 9
RohitMane_
Then you need to update case COMMAND_LOAD_TOOL (Line no : 2162).
Search for case COMMAND_LOAD_TOOL in the code, and modify or replace the code below that line as shown in the example below. You can remove the commented-out section if you wish.
  case COMMAND_LOAD_TOOL:
    setSpindleLoadMonitor(false); // disable spindle load monitoring
    writeComment(tool.comment);
    var toolCall = "T" + toolFormat.format(tool.number);
    if (getProperty("preloadTool")) {
      if (getProperty("safeToolChange")) {
        writeBlock("IF [ VTLCN EQ", toolFormat.format(tool.number), "]", skipNLines(5));
        writeBlock("IF [ VTLNN EQ", toolFormat.format(tool.number), "]", skipNLines(3));
        writeBlock("IF [ VTLNN EQ 0 ]", skipNLines(2));
        writeBlock(mFormat.format(64));
        // writeToolBlock(mFormat.format(6), toolCall);
        writeBlock(gFormat.format(116), toolCall);  // new code
      } else {
      //   if (!isFirstSection()) {
      //     writeComment(toolCall);
      //     writeToolBlock(mFormat.format(6));
      //   } else {
      //     writeToolBlock(toolCall, mFormat.format(6));
      var preloadTool = getNextTool(tool.number != getFirstTool().number);
      if (preloadTool) {
        writeBlock("T" + toolFormat.format(preloadTool.number)); // preload next/first tool
      } else if (getProperty("safeToolChange")) {
        writeBlock(formatComment("*"));
    } else {
        writeBlock("IF [ VTLCN EQ", toolFormat.format(tool.number), "]", skipNLines(2));
      } else {
    setProperty("showSequenceNumbers", saveShowSequenceNumbers);
    return;
Message 5 of 9
info
Hi @RohitMane_ ,
Thanks for the great suggestion for the change, but now if I activate the sequence number “tool change only” , it doesn't insert the numbering.
Message 6 of 9
RohitMane_
Oh, yes, that’s correct.
Please change the function name from writeBlock to writeToolBlock only on the new code lines. Then you’ll get the sequence number on the tool change line.
before change
after change
writeToolBlock(gFormat.format(116), toolCall);  // new code​
Message 7 of 9
info
Hi @RohitMane_ ,
Perfect, it works perfectly.
I would like to make another change.
I would like the program name written in the first line to be written between (), as if it were a comment, so that the machine tool does not read it. Then I would also like to write the date and time of the program writing before the tool list. Thank you.
Message 8 of 9
RohitMane_
To include the program name as a comment, replace writeln with  writeComment  on line number 590.
To insert the date and time, add the following line immediately after that statement.
var d = new Date();
writeComment("Creation date: " + d.toLocaleDateString() + " " + d.toLocaleTimeString());
Message 9 of 9
info
 Hi @RohitMane_ ,
Perfect, thank you for the suggestions.
Kind regards
