Needing Help on Mazak VC500-A 5 axis post
We have a new machine in our shop. Its a Mazak VC 500-A 5 axis. It is  B & C trunion style machine. Its has the new smooth control.  There are a few issues that we are having with the Mazak post. I can get it to post out the program with the correct B and C moves, but it is also posting out an A value in the program. The machine will bomb out if it sees the A in the program. Any help to fix the post on that issue would be great. Also I would like to see the post match our current post that we have from surfcam(Below). We recently switched over to fusion from surfcam 18. I havnt messed with posts much so, im not exactly sure where to get started. Below is what our current post looks like from the beginning of the program.
Thanks for and and all advise!
Beginning of program
(00001)
(G54.1 PROGRAMMED)
G90 G80 G40 G49
(POST REVISION 10)
(OPERATION 1 - 3+2)
(TOOL CHANGE IN OPERATION)
(+B ROTATION DEFAULT IN OPERATION)
(NEW ROTATION)
(RETRACT FOR TOOL CHANGE)
G00 G90 G53 Z0.0
G53 B0.0 C0.0
M1
(0.2500 DIA - 4 FLUTE - ENDMILL)
N14 M6 T14
G90 G20 G94
S1650 M03
G00 X-5.006 Y-1.8892 M08
B88.5 C0.
G43 Z15. H14
G61.1
G00 Z8.3354
G01 Z8.2354 F3.
G03 X-5.0998 Y-1.7954 Z8.2333 I-.0938 J0.
G03 X-5.1936 Y-1.8892 Z8.2313 I0. J-.0938
(End of Program)
M09
M05
(RETRACT TO MACHINE HOME)
G00 G90 G53 Z0.0
G53 B0.0 C0.0
G00 G90 G53 Z0.0
G53 X0.0 Y0.0
G53 B0.0 C0.0
M30
I work for NexGenCam .  We're and Autodesk Advanced Partner, and we offer Advanced support. We can diagnose, tune or create post processors for hundreds of machines.
 Email me.    [email protected]. (paid for service)    I'll send you a return email with what we need from you to fix the problem, along with an up front Quote, and coverage going forward.   When you compare what it cost in frustration, down time, producing potential bad parts, or inaccurate information, our advanced support pays for itself in short order.
