need correct post processor.
I have a Multi-cam c-204. The machine doesn't seem to recognize feed optimization causing it to take corners fast and throw the path out of alignment. I was hopping someone could send me the proper post to see if this is the issue. thanks.
bob.schultz
It is possible that a single code can alleviate this problem.  For the Multicam router it looks like it would be the following code.
G27 - Continuous Sequence Operation with Automatic Speed Reduction on Corners
If you have documentation specific to your control, you could look at the support G-codes to see if this code is supported or another code is used.
Can you add this code to your NC file and see if it fixes this issue.  If so, then it is easy enough to get the post to output this code.  If it doesn't work, you can try outputting G09 on every motion block.  This code is only valid for the block it is programmed in and will cause the machine to stop exactly at each programmed location.
Bob Schultz
Sr. Post Processor Developer
