Multiple WCS Offsets and Subprograms
jbthornhill
jbthornhill
I am wondering if any progress has been made with being able to post out subprograms with multiple WCS offsets and the posts not creating separate subs for identical operations in each offset?
I realize that I can stitch this kind of thing together for a more production oriented environment, but it's not worth the effort for smaller runs. It is advantageous and safer to only make edits in 1 place instead of 2 or more. I've found a few threads from the past talking about this same thing, but there seems to be no updates on whether this is coming?
bob.schultz
We do have the 'Use subroutine pattern' property in a number of our stock posts that will create a single subprogram for identical tool paths created using a Pattern in HSM.  What post are you using and have you noticed this property in the Post Property Table when posting?
Bob Schultz
Sr. Post Processor Developer
dmartinS68QJ
Adding to Bob's comment,  I had to test with the multiple FANUC generic posts and tinkering with the various options.  I was able to get pretty close to your expectation: main program calls multiple WCS changes, then sub is created as defined per fusion tool operation.
The combination that was closest to what I needed was as follows:
fanuc generic post
useSubroutines: true,
useSubroutinePatterns: true,
useSubroutineCycles: false,
Ironically, for me the "Fanuc generic with subs" post was further from what I wanted than the fanuc generic post.
-Dan
