Running a MultiCam series 7000 gantry router and the post is a mess. At the moment, the post isn't converting 3D toolpaths correctly. It mostly struggles with anything outside of the x-y plane; the post doesn't handle G2 G3 arc moves in the x-z or y-z planes; it doesn't do ramping (i.e. helical ramps); the feedrate posts as in/min when the machine interprets an in/s feedrate. Not really sure how to approach this problem but it's crippling for the machine. We try to run as much smoothing as possible on these large foam moulds we are machining and because the smoothing dumps a tonne of G2 G3 moves into the toolpath, the machine will just crash with what the post processor outputs. I think the problem is the machine's left hand coordinate system and the conversion the post tries to make. Anyhow, the machine runs terribly without smoothing, anyone else with these problems?
