I am new to both MultiCam and Fusion. I have already discovered the feed rate problem but I'm having an issue where the Multicam is not seeing the correct z origin or it is offsetting the tool path in the wrong direction.
I am following the MultiCam 3000 Instructions and setting tool height on the top of the item to be milled. All of the tools are zeroed in the correct fashion.
I also set the max depth at the surface of the machine.
The indications are that the post processor adds the thickness of the part to the top of the tool height and uses that as a start point
The hand held control shows Z= 0.000 when the tool is on top of the part. the G code shows -2.00" for a 2" part top which is actually 2" above the top of the part.
The part origin is Z up and the X-Y plane on the machine surface.
Any help would be appreciated.
Solved by mcarver. Go to Solution.
pmgroupsg
This sounds like a simple miss-understanding on the setup of the job in the software. If I understand you correctly you are setting the wcs on the table in the cam software. So it is thinking that the tool needs to be at a height of -2 when the tool is at the top of the part. Where you are setting the zero in your machine to the top of the part. So when the code is posted a value of -2 is expected to be the top of the part where it is zero in your machine.
All you need to do to fix this is move the wcs in Fusion to the top of the part. This should then match your machine and fix your issue.
To me it feels like the machine's Z-axis is inverted.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Moving the origin to the top of the part did in fact fix my problem. It took me a little time to actually do it and test it on the machine.
It seems that when I use the auto bit sensor to set the workpiece height it resets Z -0 to the plane at the top of the material There is a second setting of the max depth the cutters can go and that is normally set at the machine surface. It seems that this is more of a safety setting to protect the spoil board, or if this was a CNC Mill the top of the work holding surface.
Have you dealt with the retracts on drilling? The retract is opposite on this machine. Multicam said “its a cnc not a milling machine” !
Lol yes! I found the ips issue today as well. I now know how fast you can cut HDPE, ****ty edge but super fast! Ill be trying to figure out the post processor out all week for that one!
