Multi Line Output
Multi Line Output
ericbUU8RW
Multi Line Output
ericbUU8RW
The following code outputs tool information
 var tools = getToolTable();
    if (tools.getNumberOfTools() > 0) {
      for (var i = 0; i < tools.getNumberOfTools(); ++i) {
        var tool = tools.getTool(i);
        var comment = "T" + toolFormat.format(tool.number) + " " +
          "D=" + xyzFormat.format(tool.diameter) + " " +
          localize("CR") + "=" + xyzFormat.format(tool.cornerRadius);
        if ((tool.taperAngle > 0) && (tool.taperAngle < Math.PI)) {
          comment += " " + localize("TAPER") + "=" + taperFormat.format(tool.taperAngle) + localize("deg");
        if (zRanges[tool.number]) {
          comment += " - " + localize("ZMIN") + "=" + xyzFormat.format(zRanges[tool.number].getMinimum());
        comment += " - " + getToolTypeName(tool.type);
        writeComment(comment);
Like this
(T1 D=2.5 CR=0.125 - BULLNOSE END MILL)
(T2 D=0.625 CR=0.125 - BULLNOSE END MILL)
(T5 D=0.5 CR=0.25 - BALL END MILL)
(T8 D=0.25 CR=0. - FLAT END MILL)
(T12 D=0.2656 CR=0. TAPER=118DEG - DRILL)
(T13 D=0.375 CR=0. TAPER=120DEG - SPOT DRILL)
(T15 D=0.75 CR=0. - FLAT END MILL)
(T16 D=0.375 CR=0. - FLAT END MILL)
(T17 D=0.06 CR=0.062 - RADIUS MILL)
(T22 D=0.269 CR=0. - REAMER)
How can I break up each tools information to its own line? Like this
(T1)
(D=2.5)
(CR=0.125)
(BULLNOSE END MILL)
How can I add a "new line" to each "comment"?
andrea.amilo
Hello @ericbUU8RW ,
you can replace the 'comment' variable with the 'writeComment' command, as shown here:
I made this modification in the generic Fanuc post, but it should be the same for any other post.
Please test it carefully and let me know.
Andrea Amilo
Senior Technical Consultant
Autodesk Knowledge Network | Fusion 360 Webinars | Autodesk Make
