Mist and Air coolant post together
KRoser_12
KRoser_12
Hi guys just a quick question. Is posible to have two mcodes in one coolant option. I have separate m codes to activate mql and air cooling on my machine. 99% time i use mql (M7) but there are some times when i need aditional air (M50) so when i program air cooling in inventor then output will be M7
M50.
I hope that i explained my problem well with my english knowledge.
Thanks for help
GeorgeRoberts
Thanks for posting. You can modify your post processor to support multiple coolant commands like this. If you would be willing to share you post, I could advise on what modifications are needed
Cheers
George Roberts
Manufacturing Product manager
If you'd like to provide feedback and discuss how you would like things to be in the future, Email Me and we can arrange a virtual meeting!
AchimN
@KRoser_12 sure this is possible.
Here is a sample taken from the generic HAAS UMC750 post:
function setCoolant(coolant) {
  if (isProbeOperation()) { // avoid coolant output for probing
    coolant = COOLANT_OFF;
  if (coolant == currentCoolantMode) {
    return; // coolant is already active
  var m = undefined;
  var m2 = undefined;
  if (coolant == COOLANT_OFF) {
    if (currentCoolantMode == COOLANT_THROUGH_TOOL) {
      m = 89;
    } else if (currentCoolantMode == COOLANT_AIR) {
      m = 84;
    } else if (currentCoolantMode == COOLANT_AIR_THROUGH_TOOL) {
      m = 74;
    } else if (currentCoolantMode == COOLANT_FLOOD_THROUGH_TOOL) {
      m = 89;
      m2 = 9;
    } else {
      m = 9;
    writeBlock(mFormat.format(m));
    if (m2) {
      writeBlock(mFormat.format(m2));
    currentCoolantMode = COOLANT_OFF;
    return;
  if (currentCoolantMode != COOLANT_OFF) {
    setCoolant(COOLANT_OFF);
  switch (coolant) {
  case COOLANT_FLOOD:
    m = 8;
    break;
  case COOLANT_THROUGH_TOOL:
    m = 88;
    break;
  case COOLANT_AIR:
    m = 83;
    break;
  case COOLANT_AIR_THROUGH_TOOL:
    m = 73;
    break;
  case COOLANT_FLOOD_THROUGH_TOOL:
    m = 88;
    m2 = 8;
    break;
  default:
    warning(localize("Coolant not supported."));
    if (currentCoolantMode == COOLANT_OFF) {
      return;
    m = 9;
  if (m2) {
  currentCoolantMode = coolant;
Achim.N
Principal Technology Consultant
KRoser_12
Thanks for super quick response, there is my post.
KRoser_12
I looked at that sample from UMC750, but I didn´t fully understand that. But right now it finally hit me :). I make my changes and it works (so far now at least). Thanks guys.
