Missing Probing Measurement Code
abrownAG8YF
abrownAG8YF
I've set up three probing cycles on my part (see attached) that simulate well but don't output correctly using the generic Fanuc post. Below is the code that I get when I post the part, and as you can see only the probe on, off, and protected positioning cycles are posting, not the actual measuring cycles. Any ideas anyone?
Thanks in advance.
(PROBE Y-AXIS WORK SHIFT)
M06 T21
G54.1 P1
G00 A-90. C-90.
G5.1 Q1
G00 X-6.9175 Y0.
G43 Z0.31 H21
G65 P9832
G65 P9810
G65 P9833
(PROBE Z-AXIS WORK SHIFT)
G00 X-6.9175 Y0.
G65 P9832
Z0.31
G65 P9810
G65 P9833
(PROBE X-AXIS WORK SHIFT)
G00 X-6.1848 Y0.
G65 P9832
Z0.31
G65 P9810
G65 P9833
M05
G53 G00 Z0.
G49
G5.1 Q0
bob.schultz
The Fanuc post processor will output a 'G65 P9811' block with the XYZ probing cycles.  Are you running the latest version located here or are you running a modified version?
Bob Schultz
Sr. Post Processor Developer
