Milltronics Lathe Post Processor
Message 1 of 17
I am trying to get a good post processor for my milltronics lathe, In another Post it was suggested to use a generic fanuc Post Processor  It works ok most of the time, but I am having a threading issue In the Generic Fanuc Post processor, that I downloaded and renamed, Milltronics Turning, the threading feedrate defaults to .040. I have changed the pitch on my tool in the tool library, as well as set it in the threading box if fusion. all looks good until I post it then I get a feedrate of .040 instead of the .083333 that I require. I posted it for my Haas CL-1 lathe and it posts out perfect.
below is a link to the other post that I have been describing my issues in. there you will find the actual post processor and file that I am using to sort this out.
Any help is sure appreciated
https://forums.autodesk.com/t5/fusion-360-computer-aided/post-processor-for-a-milltronics-lathe/m-p/...
Replies (16)
Message 2 of 17
seth.madore
You need to be setting your Pitch at the toolpath level, not insert:
That yields this toolpath:
N14 T0400
N15 G54
N16 M8
N17 G99
N18 G97 S500 M3
N19 G0 X4.3 Z0.1969
N20 G0 Z0.1
N21 G92 X1.984 Z-2. F0.07874
N22 X1.968
N23 X1.952
N24 X1.936
N25 X1.92
N26 G0 X4.3 Z0.1969
Seth Madore
Message 3 of 17
N14 T0400
N15 G54
N16 M8
N17 G99
N18 G97 S500 M3
N19 G0 X4.3 Z0.1969
N20 G0 Z0.1
N22 X1.968
N23 X1.952
N24 X1.936
N25 X1.92
N26 G0 X4.3 Z0.1969
please notice the screen shot below, I have the thread pitch set correctly but am still getting the same result
Message 4 of 17
seth.madore
Alright, sorry, I missed that. Please share your post processor here. What I posted above was the generic Fanuc turning post. You should be getting the same. Since you aren't I'd like to see why...
Seth Madore
Message 5 of 17
Good Morning;
Sure I'll attach it below.
I have tried to post the same path out for our Haas lathe and it posted correct. in fact i copied and pasted it into my milltronics program and it work fine other than I had to add an M6 for the tool change.
Thanks Again
Message 6 of 17
seth.madore
Alright, I found the culprit. When it's "Use Cycle", it posts out the correct feedrate. When it's not "Use Cycle", it defaults to a 1mm feedrate. I've notified the post team and will post back shortly with a solution
-EDIT#1- This exists in your post only, not the current Fanuc Turning Post. If you haven't done any other changes to the post, I'd just suggest grabbing that one.
-EDIT#2- Your post hails from Oct. of 2013... The new Fanuc post was last updated on 12/2018. Suffice to say that there have been more than a few upgrades..
Seth Madore
Message 7 of 17
Well, turning the cycle on only made 1 threading pass and didn't actually cut anything, but I just downloaded the newest fanuc post and it looks better , Im getting ready to go try it out now and will update you.
Message 8 of 17
Well that didnt work, I left out my m6's for my toolchange and added a G28 U0. that gave me an error.  Threading pass looks good tho.
Message 9 of 17
seth.madore
Well, we can add an M6 callout, that's not issue.
Did you want it like:
N48 T0400
M6
N49 G54
and then at the end of the toolpath, what are you looking for?
Seth Madore
Message 10 of 17
M06T404
Message 11 of 17
seth.madore
ok... and what about at the end of a tool cycle, you do not want it to go home. What then?
Seth Madore
Message 12 of 17
The book says
X to tool change (G48)
 The G48 function will retract X to the tool change position. This position is set by the machine tool builder But may be change by editing the Tool Change Coordinate Parameters
Same for Z
 So I guess it would be
G48
G49
in that order
Message 13 of 17
seth.madore
Do you have working code for your machine? Anything that's been run with success?
Seth Madore
Message 14 of 17
My Bad,
 should be
G48
G47
G48 for X
G47 for Z
Message 15 of 17
Yes Sir;
I am currently running the 1 attached below
Message 16 of 17
seth.madore
Sorry for the delay, it's been a busy day in the shop. Give the attached post a shot. It's the generic Fanuc with a couple tweaks;
No G28 U0. or W0., using G47 and G48 instead
M6 at every tool change
Test carefully. Not responsible for any undesirable results 🙂
Seth Madore
Message 17 of 17
Im running a little behind myself, lol, i tried out that post processor yesterday, and it seems to work great. Didnt have any hicups at all. I want to thank you for all your help. Pat Burden Sektam of Independence Inc. Www.sektam-indy.com
