Mazak Integrex wrong B-axis output.
L_shaver_6167
Message 1 of 22
L_shaver_6167
 In this example, the B-axis is correctly countered (B90,B0) for individually selected jobs. But if both are counted together then the second job will also be with B90. what was miscalculated.
Post for Mazak Integrex i-400S (autodesk.com)
Replies (21)
Message 2 of 22
billcainautodesk
Hello L_shaver_6167
I am not sure of the actual problem. Can you explain a little more and if possible please upload the .f3d file your having this problem with?
Bill Cain
Sr. Technical Consultant
Message 3 of 22
L_shaver_6167
second job of setup 1 is B-axis still at 90 ° from previous job.
greeting
Message 4 of 22
L_shaver_6167
greeting
@billcainautodesk
Message 5 of 22
billcainautodesk
After the tool changes the B will already be at B0 so there is no need to to have a B0. output.
Bill Cain
Message 6 of 22
L_shaver_6167
Hello, Thanks for the answers, but I think something else doesn't fit. Please make the output of setup 2, once with the Y-axis option and once without, you get two different B-axis values. Something seems to be wrong here. Thank you@billcainautodesk
Message 7 of 22
billcainautodesk
Yes, I see it now. I'll look into why this is happening.
Bill Cain
Message 8 of 22
billcainautodesk
Hello L_shaver_6167
Thank you for reporting this and helping me understand the problem. I'll get our library posts updated.
To fix it we need to change this line
            abc = new Vector(-abc.x, abc.y, -abc.z); // needed for secondary spindle
        } else {
          abc = getWorkPlaneMachineABC(currentSection, currentSection.workPlane);
        if (!machineState.useXZCMode && !machineState.usePolarMode) {
          setWorkPlane(abc);
to this
        } else {
        if (gotBAxis) {
          setWorkPlane(abc);
Bill Cain
Message 9 of 22
billcainautodesk
One other change needs made. Put the // in front of these 2 lines or some milling will come out in X Diameter mode.
  //if (!currentWorkPlaneABC) {
  if (machineState.isTurningOperation) { // diameter mode
    writeBlock(gFormat.format(10.9), "X1"); // diameter input mode
    xFormat.setScale(2); // diameter mode
    xOutput = createVariable({prefix:"X"}, xFormat);
  } else { // radius mode
    writeBlock(gFormat.format(10.9), "X0"); // radius input mode
    xFormat.setScale(1); // radius mode
Bill Cain
Message 10 of 22
L_shaver_6167
Hello @billcainautodesk ,
thank you very much, it looks better now. Please take a look at this second example. Setup 1 / Job 1/2 B-axis 90/90 incorrect. Right 90/0.
Job 2 alone is then correctly output with B0.
Thanks and regard
Message 11 of 22
billcainautodesk
Hello L_shaver_6167
I see what's happening and will look into it. Thank you
Bill Cain
Message 12 of 22
billcainautodesk
Hello L_shaver_6167
I believe I found the problem but am double checking with my coworker. Should get back to you soon.
Bill Cain
Message 13 of 22
L_shaver_6167
Hello @billcainautodesk , while you're at it, here are a few mistakes. I have attached 1001 (main spindle) and 1002 (secondary spindle) the correspondence should be marked with ***.
greeting
Message 14 of 22
billcainautodesk
Hello L_shaver_6167
Sure thing, Happy to have all feedback. Thank you.
We found a few more issues while working on the B angles also. I want to get that round in and approved but will start looking at these also.
Bill Cain
Message 15 of 22
billcainautodesk
Hello L_shaver_6167
The updated post is now on the website. Pretty sure we got all the current issues. Thanks for your help and feedback.
Bill Cain
Message 16 of 22
L_shaver_6167
Hello @billcainautodesk , the B-axis seems to be OKAY now. Unfortunately, the problem is the subspindle with tapping cycle, Z axis should have „+“ output. Look at the file in post #13, marked the bugs with „***“. I also think that the C-axis is twisted 180 degrees on the subspindle during milling. However, when drilling without a Y-axis, the C-axis output fits. That's weird. Thanks and greetings
Message 17 of 22
billcainautodesk
Hello L_shaver_6167
We are looking into everything. I also saw your other post about missing Y0 move.
Bill Cain
Message 18 of 22
billcainautodesk
Hello L_shaver_6167
The C axis is rotated because of the direction of the X axis in the set up. If you reverse the X axis the C axis will not be rotated 90 degrees anymore. I did notice that this makes the operation milling at C180 mill at the bottom of the part so it may sometime be desirable to have another set up with the X axis pointed the current direction.
We are still working on the rest.
Bill Cain
Message 19 of 22
L_shaver_6167
Hi @billcainautodesk ,
to get the output as in the picture is not possible?
Discovered another mistake, hopefully you won't be angry with me. G18 / G41 / G17 G17 should come before radius compensation.
Thank you
Message 20 of 22
billcainautodesk
Hello L_shaver_6167
There is an updated version on the website. It should cover everything including we have it outputting G17 and G18 at the beginning of each process now. We are am look at this C angle thing now.
Bill Cain
