Mach3 post processor M3/M5 Gcode
Hello
I need a little help to get this gcode out of my mach3 post processor.
But how should I do that?
I have been playing with different settings but can not find the correct place to do the inputs.
G00 Z0
G00 X-100,0197 Y-5,9306 F300 M3 S8000
G00 Z-0,078
G01 X-96,8153 Y-5,4911 F3000 S100 M3
G01 X-96,7295 Y-7,543
G01 X-96,345 Y-8,9472
G01 X-95,6618 Y-9,7037
M5
G01 X-94,9774 Y-10,4613 F3000 S100 M3
G00 Z-0,078
G01 X-94,0321 Y-10,8389
G01 X-92,8236 Y-10,8378
G01 X-91,9321 Y-10,8389
M5
G010Z-0,078
M5
M30
So it use:
Feed
Speed
Start/Stop (M3/M5) between the moves.
Do you know how to do it?
Marek_Skotak
 you can try something like this. Not tested, only idea from my head.
function onRapid(_x, _y, _z) {
  var x = xOutput.format(_x);
  var y = yOutput.format(_y);
  var z = zOutput.format(_z);
  if (x || y || z) {
    if (pendingRadiusCompensation >= 0) {
      error(localize("Radius compensation mode cannot be changed at rapid traversal."));
      return;
    writeBlock(gMotionModal.format(0), x, y, z);
 	feedOutput.reset();
  // this is my code
var first_move = true
function onLinear(_x, _y, _z, feed) {
  var f = feedOutput.format(feed);
// this is my code
if (fist_move) {
writeBlock (sOutput.format(tool.spindleRPM), mFormat.format(tool.clockwise ? 3 : 4))
writeBlock(gMotionModal.format(1), x, y, z, f);
first_move = false
  if (x || y || z) {
      pendingRadiusCompensation = -1;
      writeBlock(gPlaneModal.format(17));
      switch (radiusCompensation) {
      case RADIUS_COMPENSATION_LEFT:
        pOutput.reset();
        writeBlock(gMotionModal.format(1), gFormat.format(41), x, y, z, f, pOutput.format(tool.diameter));
        break;
      case RADIUS_COMPENSATION_RIGHT:
        pOutput.reset();
        writeBlock(gMotionModal.format(1), gFormat.format(42), x, y, z, f, pOutput.format(tool.diameter));
        break;
      default:
        writeBlock(gMotionModal.format(1), gFormat.format(40), x, y, z, f);
    } else {
  } else if (f) {
    if (getNextRecord().isMotion()) { // try not to output feed without motion
      feedOutput.reset(); // force feed on next line
    } else {
      writeBlock(gMotionModal.format(1), f);
Marek
www.cadcam-softcz.cz
Postprocessor writer, CNC trainer, .NET programmer, www.cadcam-softcz.cz
Sorry but it didnt work.
But this is the output I am looking for:
G1X39.0928Y35.8210
M5
G0X43.0084Y35.2696
G1X43.3356Y35.2296S12000F3600.0
G1X42.3434Y35.3599
Where do I have to edit.
daniel_lyall
why do you wont M3 and M5 to go off and on between moves
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
