Second Z axis router
Solved by whizbanger. Go to Solution.
Can you please add a demo fusion file (with some toolpaths) so I can check the output/Verify?
Visual Studio Code
While searching for ways to resolve this myself I came across a very interesting video from NYCCNC where John explains how to use Visual Studio Code to modify his PostP files. I love the way it shows live editing of the PostP next to the linked cut file. I tried for several hours to get it to work with Shopbot's SBP files as opposed to him working with NC files, but I couldn't figure it out. I'd be willing to pay someone to assist me in setting this up if it's possible for SBP files.
Cheers
I was able to make all of the changes except for the last one with the two routers, I have to think about that a bit more. The reason your feedrate gets limited is because in the post there is parameter for max Z feedrate which is limited to 180 ipm whenever there is a Z movement. I can change this to 270 if you want but i'm not sure if its a limitation on your machine or not.
Thanks to @Mattxer for fixing a couple of problems that I originally identified in my post.
Thanks to John Saunders at NYCCNC for creating his video & introducing me to VSC.
Over the years I've made simple mods to posts for other, simpler CAM software I use, but I'm not a programmer & a lot of the terminology & formatting I see in a post is foreign to me. I can identify the changes I need made from my cut files, they're usually simple, and whenever possible I want to make the fixes in the post myself.
In this case, nobody actually helped me with my requests regarding using VSC for this purpose, so I just kept messing around in it until I learned what I needed. For me it's a game-changer in how I review & edit my posts (and even my cut files). It's an awesome tool that I highly recommend for people in a similar situation.
Daren
