Insert Custom Code Between Setups
wileydavis
wileydavis
I need to insert the following code in between two setups when posting a single program with two setups:
G53 X-14. Y0.
M52
G04 P1.
M62
M00
We uncheck "minimize tool changes" so that each setup runs sequentially, but in order to interface with our robot, I'd like to have the post insert the above code in between setup 1 and setup 2. I'm comfortable modding the post (ours is already heavily modified from the standard haas post) but if someone can point me in the right direction as to where to look I'd appreciate it.
Cheers,
w
makko74
maybe with getJobId()
in onSection
  if ( !isFirstSection() && ( currentSection.getJobId() != getPreviousSection().getJobId() ) ) {
    writeBlock("G53 X-14. Y0.");
    writeBlock("M52");
not tested
Mario
InfoInventor CAM(Ultimate) user --- Inventor Professional 2021.2 + Inventor CAM Ultimate 8.1.2.21785
wileydavis
That worked perfectly. Thank you very much.
makko74
You're welcome
Glad that it work for you.
Have Fun
Mario
