If you do post customization
fonsecr
Alumni Alumni
fonsecr
If you are doing post customization you have likely been using the "dump.cps" post to get a good overview of the toolpath passed to be post.
I added 2 new properties that can be helpful in understanding what is going on. I added these to fix an issue for guided deep drilling will be available in HSMWorks 2017 🙂
"showState" will the often relevant current state like expected current position and spindle speed. The lines that have the prefix "STATE" are output by dumpState() you can adjust this function is you want more information.
"expandCycles" will cause the canned cycles to be expanded. The expanded commands will use the prefix "EXPANDED". If a cycle cannot be expanded it will just be skipped and a note will be output in its place
Both properties are enabled by default.
1777: onCyclePoint(240, -30, -95)
1777: EXPANDED onSpindleSpeed(200)
1777: EXPANDED onRapid(240, -30, 20)
1777: EXPANDED onRapid(240, -30, 10)
1777: EXPANDED onRapid(240, -30, -83.75)
1777: EXPANDED onLinear(240, -30, -89.75, 9999)
1777: EXPANDED onSpindleSpeed(5200)
1777: EXPANDED onLinear(240, -30, -95, 300)
1777: EXPANDED onLinear(240, -30, -83.75, 9999)
STATE position=[240, -30, 10]
STATE spindleSpeed=200
STATE radiusCompensation=RADIUS_COMPENSATION_OFF // off
1778: onCyclePoint(230, -30, -95)
1778: EXPANDED onSpindleSpeed(200)
1778: EXPANDED onRapid(230, -30, 10)
1778: EXPANDED onRapid(230, -30, -83.75)
1778: EXPANDED onLinear(230, -30, -89.75, 9999)
1778: EXPANDED onSpindleSpeed(5200)
1778: EXPANDED onLinear(230, -30, -95, 300)
1778: EXPANDED onLinear(230, -30, -83.75, 9999)
STATE position=[230, -30, 10]
1779: onCyclePoint(230, -20, -95)
1779: EXPANDED onSpindleSpeed(200)
1779: EXPANDED onRapid(230, -20, 10)
1779: EXPANDED onRapid(230, -20, -83.75)
1779: EXPANDED onLinear(230, -20, -89.75, 9999)
1779: EXPANDED onSpindleSpeed(5200)
1779: EXPANDED onLinear(230, -20, -95, 300)
1779: EXPANDED onLinear(230, -20, -83.75, 9999)
STATE position=[230, -20, 10]
Also added more entry function so you can see when the spindle speed changes. E.g. for ramping movement.
  STATE position=[34.273998, -21.890827, 20]
  STATE spindleSpeed=1256
299: onRapid(34.27399826049805, -21.890827178955078, 20)
300: onRapid(34.27399826049805, -21.890827178955078, 4.998474597930908)
301: onMovement(MOVEMENT_RAMP_HELIX /*helix ramp*/)
301: onSpindleSpeed(850)
301: onLinear(34.27389907836914, -21.888891220092773, 4.900045394897461, 80)
René Fonseca
Software Architect
fonsecr
The latest version is available here:
https://cam.autodesk.com/posts/?p=dump
René Fonseca
Software Architect
