Could somebody help me with my post?
there are a few changes i need made
i might be asking in the wrong place and if i am please let me know where i should ask
i just switched to fusion 360 and i love it!!
i have attached the post i am using and the part that was used for this gcode attached
O1001 (COMMANDER BRACKET)
(T1 D=0.4375 CR=0. TAPER=118DEG - ZMIN=-1.04 - DRILL) (Put tool #s in the order they get used in program)
(T2 D=0.5 CR=0. - ZMIN=-1.04 - RIGHT HAND TAP)
(T3 D=0.5 CR=0. - ZMIN=-0.44 - FLAT END MILL)
G90 G94 G17 G49 G40 G80
G20
G28 G91 Z0. M19 (Take this line away from the begining of the program if there is only 1 tool used in the program)
G90
(2D CONTOUR1)
T3 M06
(12 ENDMILL) (Put tool comment in with the tool change line)
T1
S8000 M03
G54
G00 X2.05 Y-1.694 (Put the G54 in with this line)
G43 Z0.1 H03 (Put the prestage tool# with this line)
M08
G01 Z0.0394 F100.
Z-0.39 F13.1
G19 G03 Y-1.644 Z-0.44 J0.05
G01 Y-1.594 F100.
G17 G03 X2. Y-1.544 I-0.05
G01 X-2.
G02 X-2.544 Y-1. J0.544
G01 Y1.
G02 X-2. Y1.544 I0.544
G01 X2.
G02 X2.544 Y1. J-0.544
G01 Y-1.
G02 X2. Y-1.544 I-0.544
X1.9092 Y-1.4835 J0.0983
G03 X1.8185 Y-1.423 I-0.0907 J-0.0378
G01 X-2.
G02 X-2.423 Y-1. J0.423
G01 Y1.
G02 X-2. Y1.423 I0.423
G01 X2.
G02 X2.423 Y1. J-0.423
G01 Y-1.
G02 X2. Y-1.423 I-0.423
G01 X1.8185
G02 X1.7262 Y-1.3615 J0.0999
G03 X1.634 Y-1.3 I-0.0922 J-0.0384
G01 X-2.
G02 X-2.3 Y-1. J0.3
G01 Y1.
G02 X-2. Y1.3 I0.3
G01 X2.
G02 X2.3 Y1. J-0.3
G01 Y-1.
G02 X2. Y-1.3 I-0.3
G01 X1.634
G02 X1.5965 Y-1.275 J0.0406
G03 X1.559 Y-1.25 I-0.0375 J-0.0156
G01 X-2.
G02 X-2.25 Y-1. J0.25
G01 Y1.
G02 X-2. Y1.25 I0.25
G01 X2.
G02 X2.25 Y1. J-0.25
G01 Y-1.
G02 X2. Y-1.25 I-0.25
G01 X1.559
G03 X1.509 Y-1.3 J-0.05
G01 Y-1.35
G19 G02 Y-1.4 Z-0.39 K0.05
G00 Z0.1
G17
M09
(FACE1)
G00 Z0.6
X2.865 Y-1.3448
Z0.2
G01 Z0.01 F100.
G18 G03 X2.815 Z-0.04 I-0.05
G01 X2.54
X-2.54
G17 G02 Y-0.9044 J0.2202
G01 X2.54
G03 Y-0.464 J0.2202
G01 X-2.54
G02 Y-0.0235 J0.2202
G01 X2.54
G03 Y0.4169 J0.2202
G01 X-2.54
G02 Y0.8573 J0.2202
G01 X2.54
G03 Y1.2977 J0.2202
G01 X-2.54
G18 G03 X-2.59 Z0.01 K0.05
G00 Z0.6
G17
M05 (Take Away M05)
G28 G91 Z0. M19
G90
G49
(DRILL1)
M01
T1 M06
T2
S2620 M03
G54
G00 X-0.8002 Y0.0255
G43 Z0.2 H01
M08
G00 Z0.1
G98 G81 X-0.8002 Y0.0255 Z-1.04 R0.06 F29.
G80
Z0.2
M09
M05
G28 G91 Z0. M19
G90
G49
(DRILL2)
M01
T2 M06
T3
S500 M03
G54
G43 Z0.2 H02
M08
G00 Z0.1
M29 S500
G84 X-0.8002 Y0.0255 Z-1.04 R0.06 P0 F38.5
G80
Z0.2
M09
G28 G91 Z0. Replace all Blue with the green at bottom
G49
G28 Y0.
M30
G0 z6.0
G28Y0.0
G28 G91 Z0.0 M19
T3 M6 (Change to prestaged tool)
M30
Sorry, I don't understand, and I don't intend to be an ass, but it looks like you know what you want; why don't you just make the changes with the (a) code editor, Parallels (included with F360), or use a text editor and do it yourself??
i just thought it might be quicker to ask on here to try and learn how to do it myself
Sorry, I made a mistake in my post.. the default/included g-code editor that comes with F360 is called Brackets. (don't know what I was thinking when I wrote that.. I almost made the same mistake writing this!). From your knowledge of the specific changes you wanted in your code, I assumed you were more familiar with its mechanics.
G-code is just simple text, and it can be edited in a dedicated Gcode editor, or even a word processor/text file program like "Word" or "Notepad"
the key is the file type extension, which should be .nc
simply open your existing g-code, make the changes and save. make sure it's in the right extension type, as mentioned above.
here is a video with a brief introduction to Brackets:
Pretty sure he wants it changed so the post will output the good code instead of manually editing code himself all the time.
Have you seen these topics?
They can probably get you on the way:
https://forums.autodesk.com/t5/hsm-post-processor-forum/post-processors-101/td-p/6101613
https://forums.autodesk.com/t5/hsm-post-processor-forum/getting-started-modify-posts/td-p/6371381
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
