How to use a tool compensation "in control" in fusion hsm?
Hello, can anybody explaine how can i use the tool comp(in control) command when programing toolpathes?
i saw it in 2d contour, but not sure that made all right
what about adaptive strategies? how can i program a code that it'll use exact tool diameter from control?
Accepted solutions (3)
Marco.Takx
Hi @Anonymous,
At the moment this isn't possible because roughing strategies has normally rest material left for finishing operations.
Also within 3D strategies, it isn't possible to use in control.
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
ArjanDijk
@Anonymous. As @Marco.Takx says only a few operation support this.
It would not make sense to have this in roughing operations as changes in tooldiameter should also influence stepover and the number of passes in a product. Because the computer calculates all this, you can not do this "in control". You can only influence the last 2D finishing pass with "in control". I prefer to only use it in 2D contour. It exists in 2D pocket, but you will have less influence over your toolpath because the settings in that operation apply for both roughing and finishing
Inventor HSM and Fusion 360 CAM trainer and postprocessor builder in the Netherlands and Belgium.
hello, did i right understood?
you mean that i should make a rough strategy without tool comp, then program some finishing strategy with it?
well in my exp, it also important for roughing
now i bought some disk mills that should be 63mm diam, but they ar 64!
hopefully it appears before roughing, because i leave about 0,5mm stock
is there finishing 3d operations that allow to use "in control" comp?
Marco.Takx
Hi @Anonymous,
I understand your issue, but it isn't possible within the Software.
Like I said normally isn't that the way of programming.
But changing the milling dimensions within the software and recalculate the toolpaths is the solution for now.
Marco Takx
ArjanDijk
Yep, just define you tool close to what they are.
A customer of mine sharpend its tools which reduced a 16mm mill to 15,2. This step was to big so he left some material. After reducing the tool in HSM everything was fine.
3D operations don't support "In control", some machines support this for complex 3D operations, but I guess this is not the field where HSM is most used.
