Announcements
How to off RTCP
alexnittii
Community Visitor
How to off RTCP
alexnittii
Community Visitor
Community Visitor
I downloaded from the site head-head postprocessor with Mach3 cnc and corrected it for head-table.
But XYZ coordinates are output seemes for rotated coordinate system.
My machine has no tilted planes and RTCP functionality.
 optimizeMachineAngles2(2) - no RTCP
If anybody advice what is needed to do more I'd be very appriciate.
Regards.
serge.quiblier
Hi @alexnittii
you are using a pretty old version of the post.
We have updated most of them to handle the machine kinematic in a different way.
But let's look at the problem:
  var aAxis = createAxis({coordinate:0, table:true, axis:[1, 0, 0], range:[-90.00, 90.00]});
  var cAxis = createAxis({coordinate:2, table:true, axis:[0, 0, 1], range:[-360.00, 360.00], cyclic:false});
There is no variable to clearly define the TCP support there. So, it will switch to the default mode. Wich is unfortunately for you to use TCP.
You must change that line to look like that
  var aAxis = createAxis({coordinate:0, table:true, axis:[1, 0, 0], range:[-90.00, 90.00], tcp:false});
  var cAxis = createAxis({coordinate:2, table:true, axis:[0, 0, 1], range:[-360.00, 360.00], cyclic:false, tcp:false});
Regards
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
alexnittii
Community Visitor
Community Visitor
Dear Serge.Q
I did like below
var aAxis = createAxis({coordinate:0, table:false, axis:[1, 0, 0], range:[-90.00, 90.00], tcp:false});
and have nc-file (machining plane perpenducular -X)
G0 A90. C-90.
G17
G0 X-91. Y-25.
Z-25.
X-81.                                     - here must be Y-81
G94 G1 X-77. F333.                Y-77
X-75.                                       Y-75
Z-50. F1000.
Still rotates WCS
Regards, Alex
bob.schultz
Hello Alex,
The program you are showing appears to be a 3+2 operation.  The optimizeMachineAngles2 function will only adjust the coordinates for multi-axis operations.  To optimize the coordinates for 3+2 operations, you will need to change the following setting in the getWorkPlaneMachineABC function from 'true' to 'false'.
  var tcp = false;  // <<< CHANGE THIS SETTING TO false
  if (tcp) {
    setRotation(W); // TCP mode
  } else {
    var O = machineConfiguration.getOrientation(abc);
    var R = machineConfiguration.getRemainingOrientation(abc, W);
    setRotation(R);
Bob Schultz
Sr. Post Processor Developer
