Help adding tool call sequence numbers & retract to Brother Speedio Post
wotdesigns
wotdesigns
I have tried all the solutions I have found on forum, but none of the text matches my post and keeps failing.
Brother/Speedio only allows jumping to sequence numbers. To start from tool 17 I would like to have Tool change 17 line call N17 so I can start from a specific tool.
Second challenge on the same post is (if it's possible) to call current tool at the end of the tool to retract the spindle. I use optional stop often and it leaves the tool in the part or immediately above it making measuring a challenge. I don't want to home the X or Y as I can reach in, but the tool is always in the way.
Help on this would be greatly appreciated!
wotdesigns
It wont let me upload the post. Only screencast??
wotdesigns
  Copyright (C) 2012-2019 by Autodesk, Inc.
  All rights reserved.
  Brother Speedio post processor configuration.
  $Revision: 42267 13d826b34503344f783e15c8e23378994271f93c $
  $Date: 2019-03-08 15:06:59 $
  FORKID {C09133CD-6F13-4DFC-9EB8-41260FBB5B08}
description = "Brother Speedio";
vendor = "Brother";
vendorUrl = "http://www.brother.com";
legal = "Copyright (C) 2012-2019 by Autodesk, Inc.";
certificationLevel = 2;
minimumRevision = 40783;
longDescription = "Generic milling post for Brother Speedio S300X1, S500X1 and S700X1 machines.";
extension = "NC";
programNameIsInteger = false;
setCodePage("ascii");
capabilities = CAPABILITY_MILLING;
tolerance = spatial(0.002, MM);
minimumChordLength = spatial(0.25, MM);
minimumCircularRadius = spatial(0.01, MM);
maximumCircularRadius = spatial(1000, MM);
minimumCircularSweep = toRad(0.01);
maximumCircularSweep = toRad(180);
allowHelicalMoves = true;
allowedCircularPlanes = undefined; // allow any circular motion
// user-defined properties
properties = {
  writeMachine: true, // write machine
  writeTools: true, // writes the tools
  preloadTool: true, // preloads next tool on tool change if any
  showSequenceNumbers: false, // show sequence numbers
  sequenceNumberStart: 10, // first sequence number
  sequenceNumberIncrement: 5, // increment for sequence numbers
  optionalStop: true, // optional stop
  o8: false, // specifies 8-digit program number
  separateWordsWithSpace: true, // specifies that the words should be separated with a white space
  useRadius: false, // specifies that arcs should be output using the radius (R word) instead of the I, J, and K words.
  useParametricFeed: false, // specifies that feed should be output using Q values
  showNotes: true, // specifies that operation notes should be output.
  useAAxis: false, // enables the A axis
  probingType: "Renishaw", // sets the probing style
  washdownCoolant: "on", // sets when/if washdown coolant should be used
  usePitchForTapping: true, // for tapping use TPI for Inch output and Pitch for MM output
  outputUnit: "inch", // can be "same", "inch", or "mm"
  doubleTapWithdrawSpeed: false, // if enabled, the withdraw speed of the tap is doubled
  useSmoothing: false // high accuracy mode
// user-defined property definitions
propertyDefinitions = {
  writeMachine: {title:"Write machine", description:"Output the machine settings in the header of the code.", group:0, type:"boolean"},
  writeTools: {title:"Write tool list", description:"Output a tool list in the header of the code.", group:0, type:"boolean"},
  preloadTool: {title:"Preload tool", description:"Preloads the next tool at a tool change (if any).", group:1, type:"boolean"},
  showSequenceNumbers: {title:"Use sequence numbers", description:"Use sequence numbers for each block of outputted code.", group:1, type:"boolean"},
  sequenceNumberStart: {title:"Start sequence number", description:"The number at which to start the sequence numbers.", group:1, type:"integer"},
  sequenceNumberIncrement: {title:"Sequence number increment", description:"The amount by which the sequence number is incremented by in each block.", group:1, type:"integer"},
  optionalStop: {title:"Optional stop", description:"Outputs optional stop code during when necessary in the code.", type:"boolean"},
  o8: {title:"8 Digit program number", description:"Specifies that an 8 digit program number is needed.", type:"boolean"},
  separateWordsWithSpace: {title:"Separate words with space", description:"Adds spaces between words if 'yes' is selected.", type:"boolean"},
  useRadius: {title:"Radius arcs", description:"If yes is selected, arcs are outputted using radius values rather than IJK.", type:"boolean"},
  useParametricFeed:  {title:"Parametric feed", description:"Specifies the feed value that should be output using a Q value.", type:"boolean"},
  showNotes: {title:"Show notes", description:"Writes operation notes as comments in the outputted code.", type:"boolean"},
  useAAxis: {title: "Use A-axis", description: "Specifies whether to use the A axis.", type: "boolean"},
  probingType: {title: "Probing type", desctiption: "Specified what probing cycles are used on the machine.", type: "enum", values: [{title: "Renishaw", id: "Renishaw"}, {title: "Blum", id: "Blum"}]},
  washdownCoolant: {title: "Washdown coolant", desctiption: "Specifies whether washdown coolant should be used and where it is output.", type: "enum", values:[{title: "Off", id: "off"}, {title: "Always on", id: "always"}, {title: "End of operation", id: "operationEnd"}, {title: "Program end", id:"programEnd"}]},
  usePitchForTapping: {title:"Use Pitch/TPI for tapping", description:"Specifies if high accuracy mode should be used.", type:"boolean"},
  outputUnit: {
    title: "Output units",
    description: "Select output units, can be same as input or forced to be Inch or MM.",
    type: "enum",
    values:[
      {title:"Same as input", id:"same"},
      {title:"Inch", id:"inch"},
      {title:"MM", id:"mm"}
  doubleTapWithdrawSpeed: {title:"Double tap withdraw speed", description:"If enabled, a L value containing double the spindle speed (up to 6000) will be output in the G77 tapping cycle.", type: "boolean"},
  useSmoothing: {title:"Use high accuraccy mode", description:"Selects whether the feedrate, or pitch in MM or TPI for Inch is output for tapping cycles.", type:"boolean"},
var singleLineCoolant = false; // specifies to output multiple coolant codes in one line rather than in separate lines
// samples:
// {id: COOLANT_THROUGH_TOOL, on: 88, off: 89}
// {id: COOLANT_THROUGH_TOOL, on: [8, 88], off: [9, 89]}
var coolants = [
  {id: COOLANT_FLOOD, on: 8},
  {id: COOLANT_MIST},
  {id: COOLANT_THROUGH_TOOL, on: 494, off: 495},
  {id: COOLANT_AIR},
  {id: COOLANT_AIR_THROUGH_TOOL},
  {id: COOLANT_SUCTION},
  {id: COOLANT_FLOOD_MIST},
  {id: COOLANT_FLOOD_THROUGH_TOOL, on: [8, 494], off: [9, 495]},
  {id: COOLANT_OFF, off: 9}
var washdownCoolant = {on: 400, off: 401};
var permittedCommentChars = " ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789.,=_-";
var gFormat = createFormat({prefix:"G", width:2, zeropad:true, decimals:1});
var mFormat = createFormat({prefix:"M", width:2, zeropad:true, decimals:1});
var hFormat = createFormat({prefix:"H", width:2, zeropad:true, decimals:1});
var dFormat = createFormat({prefix:"D", width:2, zeropad:true, decimals:1});
var xyzFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:false});
var rFormat = xyzFormat; // radius
var abcFormat = createFormat({decimals:3, forceDecimal:true, scale:DEG});
var feedFormat = createFormat({decimals:(unit == MM ? 0 : 1), forceDecimal:false});
var toolFormat = createFormat({width:2, zeropad:true, decimals:1});
var rpmFormat = createFormat({decimals:0});
var secFormat = createFormat({decimals:3, forceDecimal:true}); // seconds - range 0.001-99999.999
var taperFormat = createFormat({decimals:1, scale:DEG});
var xOutput = createVariable({prefix:"X"}, xyzFormat);
var yOutput = createVariable({prefix:"Y"}, xyzFormat);
var zOutput = createVariable({onchange: function() {retracted = false;}, prefix: "Z"}, xyzFormat);
var aOutput = createVariable({prefix:"A"}, abcFormat);
var bOutput = createVariable({prefix:"B"}, abcFormat);
var cOutput = createVariable({prefix:"C"}, abcFormat);
var feedOutput = createVariable({prefix:"F"}, feedFormat);
var cyclefeedOutput = createVariable({prefix:"F", force:true}, feedFormat);
var sOutput = createVariable({prefix:"S", force:true}, rpmFormat);
var dOutput = createVariable({}, dFormat);
// circular output
var iOutput = createReferenceVariable({prefix:"I"}, xyzFormat);
var jOutput = createReferenceVariable({prefix:"J"}, xyzFormat);
var kOutput = createReferenceVariable({prefix:"K"}, xyzFormat);
var gMotionModal = createModal({force:true}, gFormat); // modal group 1 // G0-G3, ...
var gPlaneModal = createModal({onchange:function () {gMotionModal.reset();}}, gFormat); // modal group 2 // G17-19
var gAbsIncModal = createModal({}, gFormat); // modal group 3 // G90-91
var gFeedModeModal = createModal({}, gFormat); // modal group 5 // G94-95
var gUnitModal = createModal({}, gFormat); // modal group 6 // G20-21
var gCycleModal = createModal({force:true}, gFormat); // modal group 9 // G81, ...
var gRetractModal = createModal({}, gFormat); // modal group 10 // G98-99
var gRotationModal = createModal({}, gFormat); // modal group 16 // G68-G69
// fixed settings
var firstFeedParameter = 500;
var useMultiAxisFeatures = false;
var forceMultiAxisIndexing = false; // force multi-axis indexing for 3D programs
var cancelTiltFirst = false; // cancel G68.2 with G69 prior to G54-G59 WCS block
var useABCPrepositioning = false; // position ABC axes prior to G68.2 block
var WARNING_WORK_OFFSET = 0;
var ANGLE_PROBE_NOT_SUPPORTED = 0;
var ANGLE_PROBE_USE_ROTATION = 1;
var ANGLE_PROBE_USE_CAXIS = 2;
// collected state
var sequenceNumber;
var currentWorkOffset;
var optionalSection = false;
var forceSpindleSpeed = false;
var activeMovements; // do not use by default
var currentFeedId;
var retracted = false; // specifies that the tool has been retracted to the safe plane
var g68RotationMode = 0;
var angularProbingMode;
  Writes the specified block.
function writeBlock() {
  var text = formatWords(arguments);
  if (!text) {
    return;
  if (properties.showSequenceNumbers) {
    if (optionalSection) {
      if (text) {
        writeWords("/", "N" + sequenceNumber, text);
    } else {
      writeWords2("N" + sequenceNumber, arguments);
    sequenceNumber += properties.sequenceNumberIncrement;
  } else {
    writeWords(arguments);
  Writes the specified optional block.
function writeOptionalBlock() {
    var words = formatWords(arguments);
    if (words) {
      writeWords("/", "N" + sequenceNumber, words);
  } else {
    writeWords("/", arguments);
function formatComment(text) {
  return "(" + filterText(String(text).toUpperCase(), permittedCommentChars).replace(/[()]/g, "") + ")";
  Output a comment.
function writeComment(text) {
  writeln(formatComment(text));
function onOpen() {
  if (properties.useRadius) {
    maximumCircularSweep = toRad(90); // avoid potential center calculation errors for CNC
  gRotationModal.format(69); // Default to G69 Rotation Off
  if (properties.useAAxis) { // note: setup your machine here
    var aAxis = createAxis({coordinate:0, table:true, axis:[1, 0, 0], range:[-360, 360], preference:1});
    machineConfiguration = new MachineConfiguration(aAxis);
    setMachineConfiguration(machineConfiguration);
    optimizeMachineAngles2(1); // TCP mode disabled
  if (!machineConfiguration.isMachineCoordinate(0)) {
    aOutput.disable();
  if (!machineConfiguration.isMachineCoordinate(1)) {
    bOutput.disable();
  if (!machineConfiguration.isMachineCoordinate(2)) {
    cOutput.disable();
  if (!properties.separateWordsWithSpace) {
    setWordSeparator("");
  sequenceNumber = properties.sequenceNumberStart;
    if (programName) {
    if (programComment) {
      writeComment(programName + " (" + filterText(String(programComment).toUpperCase(), permittedCommentChars) + ")");
    } else {
      writeComment(programName);
  } else {
    error(localize("Program name has not been specified."));
    return;
  // dump machine configuration
  var vendor = machineConfiguration.getVendor();
  var model = machineConfiguration.getModel();
  var description = machineConfiguration.getDescription();
  if (properties.writeMachine && (vendor || model || description)) {
    writeComment(localize("Machine"));
    if (vendor) {
      writeComment("  " + localize("vendor") + ": " + vendor);
    if (model) {
      writeComment("  " + localize("model") + ": " + model);
    if (description) {
      writeComment("  " + localize("description") + ": "  + description);
  // dump tool information
  if (properties.writeTools) {
    var zRanges = {};
    if (is3D()) {
      var numberOfSections = getNumberOfSections();
      for (var i = 0; i < numberOfSections; ++i) {
        var section = getSection(i);
        var zRange = section.getGlobalZRange();
        var tool = section.getTool();
        if (zRanges[tool.number]) {
          zRanges[tool.number].expandToRange(zRange);
        } else {
          zRanges[tool.number] = zRange;
    var tools = getToolTable();
    if (tools.getNumberOfTools() > 0) {
      for (var i = 0; i < tools.getNumberOfTools(); ++i) {
        var tool = tools.getTool(i);
        var comment = "T" + toolFormat.format(tool.number) + " " +
          "D=" + xyzFormat.format(tool.diameter) + " " +
          localize("CR") + "=" + xyzFormat.format(tool.cornerRadius);
        if ((tool.taperAngle > 0) && (tool.taperAngle < Math.PI)) {
          comment += " " + localize("TAPER") + "=" + taperFormat.format(tool.taperAngle) + localize("deg");
          comment += " - " + localize("ZMIN") + "=" + xyzFormat.format(zRanges[tool.number].getMinimum());
        comment += " - " + getToolTypeName(tool.type);
        writeComment(comment);
  if (false) {
    // check for duplicate tool number
    for (var i = 0; i < getNumberOfSections(); ++i) {
      var sectioni = getSection(i);
      var tooli = sectioni.getTool();
      for (var j = i + 1; j < getNumberOfSections(); ++j) {
        var sectionj = getSection(j);
        var toolj = sectionj.getTool();
        if (tooli.number == toolj.number) {
          if (xyzFormat.areDifferent(tooli.diameter, toolj.diameter) ||
              xyzFormat.areDifferent(tooli.cornerRadius, toolj.cornerRadius) ||
              abcFormat.areDifferent(tooli.taperAngle, toolj.taperAngle) ||
              (tooli.numberOfFlutes != toolj.numberOfFlutes)) {
            error(
              subst(
                localize("Using the same tool number for different cutter geometry for operation '%1' and '%2'."),
                sectioni.hasParameter("operation-comment") ? sectioni.getParameter("operation-comment") : ("#" + (i + 1)),
                sectionj.hasParameter("operation-comment") ? sectionj.getParameter("operation-comment") : ("#" + (j + 1))
            return;
  if ((getNumberOfSections() > 0) && (getSection(0).workOffset == 0)) {
      if (getSection(i).workOffset > 0) {
        error(localize("Using multiple work offsets is not possible if the initial work offset is 0."));
        return;
  // absolute coordinates and feed per min
  writeBlock(gFormat.format(0), gAbsIncModal.format(90), gFormat.format(40), gFormat.format(80));
  writeBlock(gFeedModeModal.format(94), gFormat.format(49), "G98");
function onComment(message) {
  var comments = String(message).split(";");
  for (comment in comments) {
    writeComment(comments[comment]);
/** Force output of X, Y, and Z. */
function forceXYZ() {
  xOutput.reset();
  yOutput.reset();
  zOutput.reset();
/** Force output of A, B, and C. */
function forceABC() {
  aOutput.reset();
  bOutput.reset();
  cOutput.reset();
function forceFeed() {
  currentFeedId = undefined;
  feedOutput.reset();
/** Force output of X, Y, Z, A, B, C, and F on next output. */
function forceAny() {
  forceXYZ();
  forceABC();
  forceFeed();
var currentSmoothing = false;
function setSmoothing(mode) {
  if (mode == currentSmoothing) {
    return false;
  currentSmoothing = mode;
  if (!mode) { // disable high accuracy mode
    writeBlock(mFormat.format(269)); // reset G332 setting to machine default
  } else if (hasParameter("operation-strategy") && (getParameter("operation-strategy") == "drill")) {
  } else if (hasParameter("operation:tolerance")) {
    var tolerance = Math.max(getParameter("operation:tolerance"), 0);
    if (tolerance > 0) {
      var stockToLeaveThreshold = toUnit(0.1, MM);
      var stockToLeave = 0;
      var verticalStockToLeave = 0;
      if (hasParameter("operation:stockToLeave")) {
        stockToLeave = xyzFormat.getResultingValue(getParameter("operation:stockToLeave"));
      if (hasParameter("operation:verticalStockToLeave")) {
        verticalStockToLeave = xyzFormat.getResultingValue(getParameter("operation:verticalStockToLeave"));
      var workMode;
      if ((stockToLeave > stockToLeaveThreshold) && (verticalStockToLeave > stockToLeaveThreshold)) {
        workMode = 265; // roughing
      } else {
        if ((stockToLeave > 0) || (verticalStockToLeave > 0)) {
          workMode = 260; // shape accuracy
        } else {
          workMode = 262; // shape & face accuracy
      writeBlock(mFormat.format(workMode)); // set tolerance mode
    } else {
      writeBlock(mFormat.format(265)); // high speed
  } else {
  return true;
function FeedContext(id, description, feed) {
  this.id = id;
  this.description = description;
  this.feed = feed;
function getFeed(f) {
  if (activeMovements) {
    var feedContext = activeMovements[movement];
    if (feedContext != undefined) {
      if (!feedFormat.areDifferent(feedContext.feed, f)) {
        if (feedContext.id == currentFeedId) {
          return ""; // nothing has changed
        forceFeed();
        currentFeedId = feedContext.id;
        return "F#" + (firstFeedParameter + feedContext.id);
    currentFeedId = undefined; // force Q feed next time
  return feedOutput.format(f); // use feed value
function initializeActiveFeeds() {
  activeMovements = new Array();
  var movements = currentSection.getMovements();
  var id = 0;
  var activeFeeds = new Array();
  if (hasParameter("operation:tool_feedCutting")) {
    if (movements & ((1 << MOVEMENT_CUTTING) | (1 << MOVEMENT_LINK_TRANSITION) | (1 << MOVEMENT_EXTENDED))) {
      var feedContext = new FeedContext(id, localize("Cutting"), getParameter("operation:tool_feedCutting"));
      activeFeeds.push(feedContext);
      activeMovements[MOVEMENT_CUTTING] = feedContext;
      activeMovements[MOVEMENT_LINK_TRANSITION] = feedContext;
      activeMovements[MOVEMENT_EXTENDED] = feedContext;
    ++id;
    if (movements & (1 << MOVEMENT_PREDRILL)) {
      feedContext = new FeedContext(id, localize("Predrilling"), getParameter("operation:tool_feedCutting"));
      activeMovements[MOVEMENT_PREDRILL] = feedContext;
    ++id;
  if (hasParameter("operation:finishFeedrate")) {
    if (movements & (1 << MOVEMENT_FINISH_CUTTING)) {
      var feedContext = new FeedContext(id, localize("Finish"), getParameter("operation:finishFeedrate"));
      activeMovements[MOVEMENT_FINISH_CUTTING] = feedContext;
    ++id;
  } else if (hasParameter("operation:tool_feedCutting")) {
      var feedContext = new FeedContext(id, localize("Finish"), getParameter("operation:tool_feedCutting"));
    ++id;
  if (hasParameter("operation:tool_feedEntry")) {
    if (movements & (1 << MOVEMENT_LEAD_IN)) {
      var feedContext = new FeedContext(id, localize("Entry"), getParameter("operation:tool_feedEntry"));
      activeMovements[MOVEMENT_LEAD_IN] = feedContext;
    ++id;
  if (hasParameter("operation:tool_feedExit")) {
    if (movements & (1 << MOVEMENT_LEAD_OUT)) {
      var feedContext = new FeedContext(id, localize("Exit"), getParameter("operation:tool_feedExit"));
      activeMovements[MOVEMENT_LEAD_OUT] = feedContext;
    ++id;
  if (hasParameter("operation:noEngagementFeedrate")) {
    if (movements & (1 << MOVEMENT_LINK_DIRECT)) {
      var feedContext = new FeedContext(id, localize("Direct"), getParameter("operation:noEngagementFeedrate"));
      activeMovements[MOVEMENT_LINK_DIRECT] = feedContext;
    ++id;
  } else if (hasParameter("operation:tool_feedCutting") &&
             hasParameter("operation:tool_feedEntry") &&
      var feedContext = new FeedContext(id, localize("Direct"), Math.max(getParameter("operation:tool_feedCutting"), getParameter("operation:tool_feedEntry"), getParameter("operation:tool_feedExit")));
    ++id;
  if (hasParameter("operation:reducedFeedrate")) {
    if (movements & (1 << MOVEMENT_REDUCED)) {
      var feedContext = new FeedContext(id, localize("Reduced"), getParameter("operation:reducedFeedrate"));
      activeMovements[MOVEMENT_REDUCED] = feedContext;
    ++id;
  if (hasParameter("operation:tool_feedRamp")) {
    if (movements & ((1 << MOVEMENT_RAMP) | (1 << MOVEMENT_RAMP_HELIX) | (1 << MOVEMENT_RAMP_PROFILE) | (1 << MOVEMENT_RAMP_ZIG_ZAG))) {
      var feedContext = new FeedContext(id, localize("Ramping"), getParameter("operation:tool_feedRamp"));
      activeMovements[MOVEMENT_RAMP] = feedContext;
      activeMovements[MOVEMENT_RAMP_HELIX] = feedContext;
      activeMovements[MOVEMENT_RAMP_PROFILE] = feedContext;
      activeMovements[MOVEMENT_RAMP_ZIG_ZAG] = feedContext;
    ++id;
  if (hasParameter("operation:tool_feedPlunge")) {
    if (movements & (1 << MOVEMENT_PLUNGE)) {
      var feedContext = new FeedContext(id, localize("Plunge"), getParameter("operation:tool_feedPlunge"));
      activeMovements[MOVEMENT_PLUNGE] = feedContext;
    ++id;
  if (true) { // high feed
    if (movements & (1 << MOVEMENT_HIGH_FEED)) {
      var feedContext = new FeedContext(id, localize("High Feed"), this.highFeedrate);
      activeMovements[MOVEMENT_HIGH_FEED] = feedContext;
    ++id;
  for (var i = 0; i < activeFeeds.length; ++i) {
    var feedContext = activeFeeds[i];
    writeBlock("#" + (firstFeedParameter + feedContext.id) + "=" + feedFormat.format(feedContext.feed), formatComment(feedContext.description));
var currentWorkPlaneABC = undefined;
function forceWorkPlane() {
function cancelWorkPlane() {
  writeBlock(gRotationModal.format(69)); // cancel frame
  forceWorkPlane();
function setWorkPlane(abc) {
  if (!forceMultiAxisIndexing && is3D() && !machineConfiguration.isMultiAxisConfiguration()) {
    return; // ignore
  if (!((currentWorkPlaneABC == undefined) ||
        abcFormat.areDifferent(abc.x, currentWorkPlaneABC.x) ||
        abcFormat.areDifferent(abc.y, currentWorkPlaneABC.y) ||
        abcFormat.areDifferent(abc.z, currentWorkPlaneABC.z))) {
    return; // no change
  onCommand(COMMAND_UNLOCK_MULTI_AXIS);
  if (!retracted) {
    if (!properties.useAAxis) {
      writeRetract(Z);
  if (useMultiAxisFeatures) {
    if (cancelTiltFirst) {
      cancelWorkPlane();
    if (machineConfiguration.isMultiAxisConfiguration() && useABCPrepositioning) {
      var angles = abc.isNonZero() ? getWorkPlaneMachineABC(currentSection.workPlane, false, false) : abc;
      writeBlock(
        gMotionModal.format(0),
        conditional(machineConfiguration.isMachineCoordinate(0), "A" + abcFormat.format(angles.x)),
        conditional(machineConfiguration.isMachineCoordinate(1), "B" + abcFormat.format(angles.y)),
        conditional(machineConfiguration.isMachineCoordinate(2), "C" + abcFormat.format(angles.z))
    if (abc.isNonZero()) {
      gRotationModal.reset();
      writeBlock(gRotationModal.format(68.2), "X" + xyzFormat.format(0), "Y" + xyzFormat.format(0), "Z" + xyzFormat.format(0), "I" + abcFormat.format(abc.x), "J" + abcFormat.format(abc.y), "K" + abcFormat.format(abc.z)); // set frame
      writeBlock(gFormat.format(53.1)); // turn machine
    } else {
      if (!cancelTiltFirst) {
        cancelWorkPlane();
  } else {
    var initialPosition = getFramePosition(currentSection.getInitialPosition());
    var _a = aOutput.format(abc.x);
    var _b = bOutput.format(abc.y);
    var _c = cOutput.format(abc.z);
    if (_a || _b || _c) {
      writeBlock(
        conditional(machineConfiguration.isMachineCoordinate(0), _a),
        conditional(machineConfiguration.isMachineCoordinate(1), _b),
        conditional(machineConfiguration.isMachineCoordinate(2), _c),
        xOutput.format(initialPosition.x), yOutput.format(initialPosition.y)
  onCommand(COMMAND_LOCK_MULTI_AXIS);
  currentWorkPlaneABC = abc;
var closestABC = false; // choose closest machine angles
var currentMachineABC;
function getWorkPlaneMachineABC(workPlane, _setWorkPlane, rotate) {
  var W = workPlane; // map to global frame
  var abc = machineConfiguration.getABC(W);
  if (closestABC) {
    if (currentMachineABC) {
      abc = machineConfiguration.remapToABC(abc, currentMachineABC);
    } else {
      abc = machineConfiguration.getPreferredABC(abc);
  } else {
  try {
    abc = machineConfiguration.remapABC(abc);
    if (_setWorkPlane) {
      currentMachineABC = abc;
  } catch (e) {
    error(
      localize("Machine angles not supported") + ":"
      + conditional(machineConfiguration.isMachineCoordinate(0), " A" + abcFormat.format(abc.x))
      + conditional(machineConfiguration.isMachineCoordinate(1), " B" + abcFormat.format(abc.y))
      + conditional(machineConfiguration.isMachineCoordinate(2), " C" + abcFormat.format(abc.z))
  var direction = machineConfiguration.getDirection(abc);
  if (!isSameDirection(direction, W.forward)) {
    error(localize("Orientation not supported."));
  if (!machineConfiguration.isABCSupported(abc)) {
    error(
      localize("Work plane is not supported") + ":"
  if (rotate) {
    var tcp = false;
    if (tcp) {
      setRotation(W); // TCP mode
    } else {
      var O = machineConfiguration.getOrientation(abc);
      var R = machineConfiguration.getRemainingOrientation(abc, W);
      setRotation(R);
  return abc;
function isProbeOperation() {
  return hasParameter("operation-strategy") && (getParameter("operation-strategy") == "probe");
var probeOutputWorkOffset = 1;
function onParameter(name, value) {
  if (name == "probe-output-work-offset") {
    probeOutputWorkOffset = (value > 0) ? value : 1;
function onSection() {
  var forceToolAndRetract = optionalSection && !currentSection.isOptional();
  optionalSection = currentSection.isOptional();
  var insertToolCall = forceToolAndRetract || isFirstSection() ||
    currentSection.getForceToolChange && currentSection.getForceToolChange() ||
    (tool.number != getPreviousSection().getTool().number);
  retracted = false;
  var newWorkOffset = isFirstSection() ||
    (getPreviousSection().workOffset != currentSection.workOffset); // work offset changes
  var newWorkPlane = isFirstSection() ||
    !isSameDirection(getPreviousSection().getGlobalFinalToolAxis(), currentSection.getGlobalInitialToolAxis()) ||
    (currentSection.isOptimizedForMachine() && getPreviousSection().isOptimizedForMachine() &&
      Vector.diff(getPreviousSection().getFinalToolAxisABC(), currentSection.getInitialToolAxisABC()).length > 1e-4) ||
    (!machineConfiguration.isMultiAxisConfiguration() && currentSection.isMultiAxis()) ||
    (!getPreviousSection().isMultiAxis() && currentSection.isMultiAxis() ||
      getPreviousSection().isMultiAxis() && !currentSection.isMultiAxis()); // force newWorkPlane between indexing and simultaneous operations
  var forceSmoothing =  properties.useSmoothing &&
    (hasParameter("operation-strategy") && (getParameter("operation-strategy") == "drill") ||
    !isFirstSection() && getPreviousSection().hasParameter("operation-strategy") && (getPreviousSection().getParameter("operation-strategy") == "drill")); // force smoothing in case !insertToolCall
  if (insertToolCall || newWorkOffset || newWorkPlane || forceSmoothing) {
    // stop spindle before retract during tool change
    if (insertToolCall && !isFirstSection()) {
      onCommand(COMMAND_STOP_SPINDLE);
    if (!insertToolCall && (newWorkOffset || newWorkPlane)) {
      // retract to safe plane
      writeRetract(Z); // retract
      forceXYZ();
    if ((insertToolCall && !isFirstSection()) || forceSmoothing) {
      // disableLengthCompensation(false);
      setSmoothing(false);
  writeln("");
  if (hasParameter("operation-comment")) {
    var comment = getParameter("operation-comment");
    if (comment) {
  if (properties.showNotes && hasParameter("notes")) {
    var notes = getParameter("notes");
    if (notes) {
      var lines = String(notes).split("\n");
      var r1 = new RegExp("^[\\s]+", "g");
      var r2 = new RegExp("[\\s]+$", "g");
      for (line in lines) {
        var comment = lines[line].replace(r1, "").replace(r2, "");
        if (comment) {
  // wcs
  if (insertToolCall) { // force work offset when changing tool
    currentWorkOffset = undefined;
  var workOffset = currentSection.workOffset;
  if (workOffset == 0) {
    warningOnce(localize("Work offset has not been specified. Using G54 as WCS."), WARNING_WORK_OFFSET);
    workOffset = 1;
  if (workOffset != currentWorkOffset) {
      cancelWorkPlane();
    forceWorkPlane();
  if (workOffset > 0) {
    if (workOffset > 6) {
      var p = workOffset - 6; // 1->...
      if (p > 300) {
        error(localize("Work offset out of range."));
        return;
      } else {
          writeBlock(gFormat.format(54.1), "P" + p); // G54.1P
          currentWorkOffset = workOffset;
    } else {
        writeBlock(gFormat.format(53 + workOffset)); // G54->G59
  var scode = "";
  if (forceMultiAxisIndexing || !is3D() || machineConfiguration.isMultiAxisConfiguration()) { // use 5-axis indexing for multi-axis mode
    if (currentSection.isMultiAxis()) {
      forceWorkPlane();
      cancelTransformation();
    } else {
      var abc = new Vector(0, 0, 0);
        var euler = currentSection.workPlane.getEuler2(EULER_ZXZ_R);
        abc = new Vector(euler.x, euler.y, euler.z);
      } else {
        abc = getWorkPlaneMachineABC(currentSection.workPlane, true, true);
      // setWorkPlane will be called below
  } else { // pure 3D
    var remaining = currentSection.workPlane;
    if (!isSameDirection(remaining.forward, new Vector(0, 0, 1))) {
      error(localize("Tool orientation is not supported."));
      return;
    setRotation(remaining);
  isSpeedDifferent = false;
  if (!isProbeOperation() && (insertToolCall ||
    isFirstSection() ||
    (rpmFormat.areDifferent(spindleSpeed, getPreviousSection().getTool().spindleRPM)) ||
    (tool.clockwise != getPreviousSection().getTool().clockwise))) {
    isSpeedDifferent = true;
    if (spindleSpeed < 1) {
      error(localize("Spindle speed out of range."));
      return;
    if (spindleSpeed > 99999) {
      warning(localize("Spindle speed exceeds maximum value."));
    forceWorkPlane();
    setCoolant(COOLANT_OFF);
    if (!isFirstSection() && properties.optionalStop) {
      onCommand(COMMAND_OPTIONAL_STOP);
    if (tool.number > 99) {
      warning(localize("Tool number exceeds maximum value."));
    var start = getFramePosition(currentSection.getInitialPosition());
    writeBlock(gFormat.format(100),
      "T" + toolFormat.format(tool.number),
      xOutput.format(start.x),
      yOutput.format(start.y),
      gFormat.format(43),
      zOutput.format(start.z),
      ((properties.useAAxis && abc) ? aOutput.format(abc.x) : undefined),
      hFormat.format(tool.lengthOffset),
      (!isProbeOperation() ? dFormat.format(tool.diameterOffset) : ""),
      (!isProbeOperation() ? sOutput.format(spindleSpeed) : ""),
      (!isProbeOperation() ? mFormat.format(tool.clockwise ? 3 : 4) : "")
    if (tool.comment) {
      writeComment(tool.comment);
    var showToolZMin = false;
    if (showToolZMin) {
      if (is3D()) {
        var zRange = currentSection.getGlobalZRange();
        var number = tool.number;
        for (var i = currentSection.getId() + 1; i < numberOfSections; ++i) {
          if (section.getTool().number != number) {
            break;
          zRange.expandToRange(section.getGlobalZRange());
        writeComment(localize("ZMIN") + "=" + zRange.getMinimum());
    if (properties.preloadTool) {
      var nextTool = getNextTool(tool.number);
      if (nextTool) {
        writeBlock("T" + toolFormat.format(nextTool.number));
      } else {
        // preload first tool
        var section = getSection(0);
        var firstToolNumber = section.getTool().number;
        if (tool.number != firstToolNumber) {
          writeBlock("T" + toolFormat.format(firstToolNumber));
  } else if (!isProbeOperation() && isSpeedDifferent) {
    writeBlock(sOutput.format(spindleSpeed));
  onCommand(COMMAND_START_CHIP_TRANSPORT);
    // writeBlock(mFormat.format(xxx)); // shortest path traverse
  if (!insertToolCall) {
    forceXYZ();
  if (abc !== undefined) {
    setWorkPlane(abc);
  // set coolant after we have positioned at Z
  setCoolant(tool.coolant);
  // add dwell for through coolant if needed
  if (tool.coolant == COOLANT_THROUGH_TOOL || tool.coolant == COOLANT_AIR_THROUGH_TOOL || tool.coolant == COOLANT_FLOOD_THROUGH_TOOL) {
    if (isFirstSection()) {
      onDwell(1);
    } else {
      var lastCoolant = getPreviousSection().getTool().coolant;
      if (!(lastCoolant == COOLANT_THROUGH_TOOL || lastCoolant == COOLANT_AIR_THROUGH_TOOL || lastCoolant == COOLANT_FLOOD_THROUGH_TOOL)) {
        onDwell(1);
  if (properties.useSmoothing) {
    if (hasParameter("operation-strategy") && (getParameter("operation-strategy") != "drill")) {
      if (setSmoothing(true)) {
        // retracted = true; // force G43
    } else {
      if (setSmoothing(false)) {
  forceAny();
  if (!retracted && !insertToolCall) {
    if (getCurrentPosition().z < initialPosition.z) {
      writeBlock(gMotionModal.format(0), zOutput.format(initialPosition.z));
  if (isFirstSection() && (properties.washdownCoolant == "always")) {
    writeBlock(mFormat.format(washdownCoolant.on));
  if (insertToolCall || retracted || (!isFirstSection() && getPreviousSection().isMultiAxis())) {
    var lengthOffset = tool.lengthOffset;
    if (lengthOffset > 99) {
      error(localize("Length offset out of range."));
      return;
    writeBlock(gPlaneModal.format(17));
    if (!machineConfiguration.isHeadConfiguration()) {
      writeBlock(
        gMotionModal.format(0), xOutput.format(initialPosition.x), yOutput.format(initialPosition.y)
    } else {
      writeBlock(
        yOutput.format(initialPosition.y),
  } else {
    writeBlock(
  if (properties.useParametricFeed &&
    (getParameter("operation-strategy") != "drill") && // legacy
    !(currentSection.hasAnyCycle && currentSection.hasAnyCycle())) {
      activeMovements &&
      (getCurrentSectionId() > 0) &&
      ((getPreviousSection().getPatternId() == currentSection.getPatternId()) && (currentSection.getPatternId() != 0))) {
      // use the current feeds
    } else {
      initializeActiveFeeds();
  } else {
    activeMovements = undefined;
  if (isProbeOperation()) {
    if (g68RotationMode != 0) {
      error(localize("You cannot probe while G68 Rotation is in effect."));
      return;
    angularProbingMode = getAngularProbingMode();
    if (properties.probingType == "Renishaw") {
      writeBlock(gFormat.format(65), "P" + 8832); // spin the probe on
function onDwell(seconds) {
  if (seconds > 99999.999) {
    warning(localize("Dwelling time is out of range."));
  seconds = clamp(1, seconds, 99999999);
  writeBlock(gFeedModeModal.format(94), gFormat.format(4), "P" + secFormat.format(seconds));
function onSpindleSpeed(spindleSpeed) {
function onCycle() {
function getCommonCycle(x, y, z, r) {
  forceXYZ(); // force xyz on first drill hole of any cycle
  return [xOutput.format(x), yOutput.format(y),
    zOutput.format(z),
    "R" + xyzFormat.format(r)];
/** Convert approach to sign. */
function approach(value) {
  validate((value == "positive") || (value == "negative"), "Invalid approach.");
  return (value == "positive") ? 1 : -1;
  Determine if angular probing is supported
function getAngularProbingMode() {
  if (machineConfiguration.isMultiAxisConfiguration()) {
    if (machineConfiguration.isMachineCoordinate(2)) {
      return ANGLE_PROBE_USE_CAXIS;
    } else {
      return ANGLE_PROBE_NOT_SUPPORTED;
  } else {
    return ANGLE_PROBE_USE_ROTATION;
  Output rotation offset based on angular probing cycle.
function setProbingAngle() {
  if ((g68RotationMode == 1) || (g68RotationMode == 2)) { // Rotate coordinate system for Angle Probing
    if (!properties.useG54x4) {
      gAbsIncModal.reset();
      writeBlock(
        gRotationModal.format(68), gAbsIncModal.format(90),
        (g68RotationMode == 1) ? "X0" : "X[#135]",
        (g68RotationMode == 1) ? "Y0" : "Y[#136]",
        "Z0", "I0.0", "J0.0", "K1.0", "R[#139]"
      g68RotationMode = 3;
    } else if (angularProbingMode != ANGLE_PROBE_NOT_SUPPORTED) {
      writeBlock("#26010=#135");
      writeBlock("#26011=#136");
      writeBlock("#26012=#137");
      writeBlock("#26015=#139");
      writeBlock(gFormat.format(54.4), "P1");
    } else {
      error(localize("Angular probing is not supported for this machine configuration."));
      return;
function onCyclePoint(x, y, z) {
  var probeWorkOffsetCode;
    if (!useMultiAxisFeatures && !isSameDirection(currentSection.workPlane.forward, new Vector(0, 0, 1)) && (!cycle.probeMode || (cycle.probeMode == 0))) {
      error(localize("Updating WCS / work offset using probing is only supported by the CNC in the WCS frame."));
      return;
    var workOffset = probeOutputWorkOffset ? probeOutputWorkOffset : currentWorkOffset;
    if (workOffset > 99) {
      error(localize("Work offset is out of range."));
      return;
    } else if (workOffset > 6) {
      probeWorkOffsetCode = -p; // G54.1P
    } else {
      probeWorkOffsetCode = ((properties.probingType == "Renishaw") ? ("G" + workOffset + ".") : (workOffset + 53)); // G54->G59
  if (isFirstCyclePoint()) {
    repositionToCycleClearance(cycle, x, y, z);
    // return to initial Z which is clearance plane and set absolute mode
    var F = cycle.feedrate;
    var P = !cycle.dwell ? 0 : clamp(1, cycle.dwell, 99999999); // in seconds
    // tapping variables
    var tapUnit = unit;
    if (hasParameter("operation:tool_unit")) {
      if (getParameter("operation:tool_unit") == "inches") {
        tapUnit = IN;
      } else {
        tapUnit = MM;
    var threadPitch = tool.threadPitch;
    if (unit != tapUnit) {
      threadPitch /= (tapUnit == IN) ? 25.4 : (1.0 / 25.4);
    var threadsPerInch = 1.0 / threadPitch;
    switch (cycleType) {
    case "drilling":
      writeBlock(
          "G98",
        gCycleModal.format(81),
        getCommonCycle(x, y, z, cycle.retract),
        cyclefeedOutput.format(F)
      break;
    case "counter-boring":
      if (P > 0) {
        writeBlock(
          "G98",
          gCycleModal.format(82),
          "P" + secFormat.format(P),
      } else {
        writeBlock(
          "G98",
          getCommonCycle(x, y, cycle.bottom, cycle.retract),
      break;
    case "chip-breaking":
      // cycle.accumulatedDepth is ignored
      if (P > 0) {
        expandCyclePoint(x, y, z);
      } else {
        writeBlock(
          "G98",
          gCycleModal.format(73),
          "Q" + xyzFormat.format(cycle.incrementalDepth),
      break;
    case "deep-drilling":
      if (P > 0) {
      } else {
        writeBlock(
          "G98",
          gCycleModal.format(83),
          //conditional(P > 0, "P" + secFormat.format(P)),
      break;
    case "tapping":
      if (!F) {
        F = tool.getTappingFeedrate();
      if (properties.usePitchForTapping) {
        writeBlock(
          gCycleModal.format((tool.type == TOOL_TAP_LEFT_HAND) ? 74 : 77),
          conditional((P != 0), "P" + secFormat.format(P)),
          conditional((tapUnit == IN), "J" + xyzFormat.format(threadsPerInch)),
          conditional((tapUnit == MM), "I" + xyzFormat.format(threadPitch)),
          conditional(properties.doubleTapWithdrawSpeed, "L" + (spindleSpeed * 2 > 6000 ? 6000 : spindleSpeed * 2))
      } else {
        writeBlock(
      break;
    case "left-tapping":
      if (!F) {
        writeBlock(
          gCycleModal.format(74),
      } else {
        writeBlock(
      break;
    case "right-tapping":
      if (!F) {
        writeBlock(
          gCycleModal.format(77),
      } else {
        writeBlock(
      break;
    case "tapping-with-chip-breaking":
    case "left-tapping-with-chip-breaking":
    case "right-tapping-with-chip-breaking":
      if (!F) {
        writeBlock(
      } else {
        writeBlock(
          gCycleModal.format((tool.type == TOOL_TAP_LEFT_HAND ? 74 : 77)),
      break;
    case "fine-boring":
      writeBlock(
        gCycleModal.format(76),
        "P" + secFormat.format(P), // not optional
        "Q" + xyzFormat.format(cycle.shift),
      break;
    case "back-boring":
      var dx = (gPlaneModal.getCurrent() == 19) ? cycle.backBoreDistance : 0;
      var dy = (gPlaneModal.getCurrent() == 18) ? cycle.backBoreDistance : 0;
      var dz = (gPlaneModal.getCurrent() == 17) ? cycle.backBoreDistance : 0;
      writeBlock(
        gCycleModal.format(87),
        getCommonCycle(x, y, cycle.bottom - cycle.backBoreDistance, cycle.bottom),
      break;
    case "reaming":
      if (P > 0) {
        writeBlock(
          gCycleModal.format(89),
      } else {
        writeBlock(
          gCycleModal.format(85),
      break;
    case "stop-boring":
      if (P > 0) {
      } else {
        writeBlock(
          gCycleModal.format(86),
      break;
    case "manual-boring":
      writeBlock(
        gCycleModal.format(88),
      break;
    case "boring":
      if (P > 0) {
        writeBlock(
      } else {
        writeBlock(
      break;
    case "probing-x":
      forceXYZ();
      // move slowly always from clearance not retract
        writeBlock(gFormat.format(65), "P" + 8810, zOutput.format(z - cycle.depth), getFeed(F)); // protected positioning move
        writeBlock(
          gFormat.format(65), "P" + 8811,
          "X" + xyzFormat.format(x + approach(cycle.approach1) * (cycle.probeClearance + tool.diameter / 2)),
          "Q" + xyzFormat.format(cycle.probeOvertravel),
          "S" + probeWorkOffsetCode // "T" + toolFormat.format(probeToolDiameterOffset)
      } else {
        writeBlock(gFormat.format(65), "P" + 8703, zOutput.format(z - cycle.depth)); // protected positioning move
        writeBlock(
          gFormat.format(65), "P" + 8700,
          "X" + xyzFormat.format(approach(cycle.approach1) * (cycle.probeClearance + tool.diameter / 2)),
          "W" + probeWorkOffsetCode // "T" + toolFormat.format(probeToolDiameterOffset)
      break;
    case "probing-y":
      forceXYZ();
        writeBlock(
      } else {
        writeBlock(
          "Y" + xyzFormat.format(approach(cycle.approach1) * (cycle.probeClearance + tool.diameter / 2)),
      break;
    case "probing-z":
      forceXYZ();
        writeBlock(gFormat.format(65), "P" + 8810, zOutput.format(Math.min(z - cycle.depth + cycle.probeClearance, cycle.retract)), getFeed(F)); // protected positioning move
        writeBlock(
      } else {
        writeBlock(gFormat.format(65), "P" + 8703, zOutput.format(Math.min(z - cycle.depth + cycle.probeClearance, cycle.retract))); // protected positioning move
        writeBlock(
          "Z" + xyzFormat.format(-cycle.depth),
      break;
    case "probing-x-wall":
        writeBlock(gFormat.format(65), "P" + 8810, zOutput.format(z)); // protected positioning move
        writeBlock(
          gFormat.format(65), "P" + 8812,
          "X" + xyzFormat.format(cycle.width1),
          "R" + xyzFormat.format(cycle.probeClearance),
      } else {
        writeBlock(gFormat.format(65), "P" + 8703, zOutput.format(z), getFeed(F)); // protected positioning move
        writeBlock(
          "S" + xyzFormat.format(cycle.width1),
          "X1",
          zOutput.format(-cycle.depth),
      break;
    case "probing-y-wall":
        writeBlock(gFormat.format(65), "P" + 8810, zOutput.format(z), getFeed(F)); // protected positioning move
        writeBlock(
          "Y" + xyzFormat.format(cycle.width1),
      } else {
        writeBlock(
          "Y1",
      break;
    case "probing-x-channel":
        writeBlock(
          // not required "R" + xyzFormat.format(cycle.probeClearance),
      } else {
        writeBlock(gFormat.format(65), "P" + 8703, zOutput.format(z - cycle.depth), getFeed(F)); // protected positioning move
        writeBlock(
          "X1",
      break;
    case "probing-x-channel-with-island":
        writeBlock(
          "R" + xyzFormat.format(-cycle.probeClearance),
      } else {
        writeBlock(
          "X1",
      break;
    case "probing-y-channel":
      yOutput.reset();
        writeBlock(
      } else {
        writeBlock(
          "Y1",
      break;
    case "probing-y-channel-with-island":
      yOutput.reset();
        writeBlock(
      } else {
        writeBlock(
          "Y1",
      break;
    case "probing-xy-circular-boss":
          writeBlock(
            gFormat.format(65), "P" + 8814,
            "D" + xyzFormat.format(cycle.width1),
            "Z" + xyzFormat.format(z - cycle.depth),
      } else {
        writeBlock(
      break;
    case "probing-xy-circular-hole":
          writeBlock(
      } else {
        writeBlock(
      break;
    case "probing-xy-circular-hole-with-island":
        writeBlock(
      } else {
        writeBlock(
      break;
    case "probing-xy-rectangular-hole":
        writeBlock(
          // not required "R" + xyzFormat.format(-cycle.probeClearance),
        writeBlock(
          "Y" + xyzFormat.format(cycle.width2),
      } else {
        error(localize("XY rectangular hole probing is not supported."));
      break;
    case "probing-xy-rectangular-boss":
        writeBlock(
        writeBlock(
      } else {
        zOutput.reset();
        writeBlock(
          "X1",
        zOutput.reset();
        writeBlock(
          "S" + xyzFormat.format(cycle.width2),
          "Y1",
      break;
    case "probing-xy-rectangular-hole-with-island":
        writeBlock(
        writeBlock(
      } else {
        error(localize("XY rectangular hole with island probing is not supported."));
      break;
    case "probing-xy-inner-corner":
        var cornerX = x + approach(cycle.approach1) * (cycle.probeClearance + tool.diameter / 2);
        var cornerY = y + approach(cycle.approach2) * (cycle.probeClearance + tool.diameter / 2);
        var cornerI = 0;
        var cornerJ = 0;
        if (cycle.probeSpacing !== undefined) {
          cornerI = cycle.probeSpacing;
          cornerJ = cycle.probeSpacing;
        if ((cornerI != 0) && (cornerJ != 0)) {
          g68RotationMode = 2;
        writeBlock(
          gFormat.format(65), "P" + 8815, xOutput.format(cornerX), yOutput.format(cornerY),
          conditional(cornerI != 0, "I" + xyzFormat.format(cornerI)),
          conditional(cornerJ != 0, "J" + xyzFormat.format(cornerJ)),
          conditional((g68RotationMode == 0) || (angularProbingMode == ANGLE_PROBE_USE_CAXIS), "S" + probeWorkOffsetCode)
      } else {
        error(localize("XY inner corner probing is not supported."));
      break;
    case "probing-xy-outer-corner":
      var cornerI = 0;
      var cornerJ = 0;
        writeBlock(
          gFormat.format(65), "P" + 8816, xOutput.format(cornerX), yOutput.format(cornerY),
      } else {
        cornerX -= x;
        cornerY -= y;
        writeBlock(
          gFormat.format(65), "P" + 8700, xOutput.format(cornerX),
          yOutput.format(cornerY), "W" + probeWorkOffsetCode
      break;
    case "probing-x-plane-angle":
      forceXYZ();
        writeBlock(
          gFormat.format(65), "P" + 8843,
          "D" + xyzFormat.format(cycle.probeSpacing),
        g68RotationMode = 1;
      } else {
        error(localize("X angle probing is not supported."));
      break;
    case "probing-y-plane-angle":
      forceXYZ();
        writeBlock(
          "Y" + xyzFormat.format(y + approach(cycle.approach1) * (cycle.probeClearance + tool.diameter / 2)),
      } else {
        error(localize("Y angle probing is not supported."));
      break;
    default:
  } else {
    if (cycleExpanded) {
    } else {
      writeBlock(xOutput.format(x), yOutput.format(y));
function onCycleEnd() {
      writeBlock(gFormat.format(65), "P" + 9810, zOutput.format(cycle.clearance)); // protected retract move
      writeBlock(gFormat.format(65), "P" + 9833); // spin the probe off
      setProbingAngle(); // define rotation of part
      // we can move in rapid from retract optionally
    } else {
      writeBlock(gFormat.format(65), "P" + 8703, zOutput.format(cycle.clearance)); // protected retract move
  } else if (!cycleExpanded) {
    writeBlock(gCycleModal.format(80));
    zOutput.reset();
  gRetractModal.reset();
var pendingRadiusCompensation = -1;
function onRadiusCompensation() {
  pendingRadiusCompensation = radiusCompensation;
function onRapid(_x, _y, _z) {
  var x = xOutput.format(_x);
  var y = yOutput.format(_y);
  var z = zOutput.format(_z);
  if (x || y || z) {
    if (pendingRadiusCompensation >= 0) {
      error(localize("Radius compensation mode cannot be changed at rapid traversal."));
      return;
    writeBlock(gMotionModal.format(0), x, y, z);
    forceFeed();
function onLinear(_x, _y, _z, feed) {
  var f = getFeed(feed);
  if (x || y || z) {
      var d = tool.diameterOffset;
      if (d > 99) {
        warning(localize("The diameter offset exceeds the maximum value."));
      switch (radiusCompensation) {
      case RADIUS_COMPENSATION_LEFT:
        dOutput.reset();
        writeBlock(gMotionModal.format(1), gFormat.format(41), x, y, z, dOutput.format(d), f);
        break;
      case RADIUS_COMPENSATION_RIGHT:
        dOutput.reset();
        writeBlock(gMotionModal.format(1), gFormat.format(42), x, y, z, dOutput.format(d), f);
        break;
      default:
        writeBlock(gMotionModal.format(1), gFormat.format(40), x, y, z, f);
    } else {
      writeBlock(gMotionModal.format(1), x, y, z, f);
  } else if (f) {
    if (getNextRecord().isMotion()) { // try not to output feed without motion
      forceFeed(); // force feed on next line
    } else {
      writeBlock(gMotionModal.format(1), f);
function onRapid5D(_x, _y, _z, _a, _b, _c) {
    return;
  if (currentSection.isOptimizedForMachine()) {
    var a = aOutput.format(_a);
    var b = bOutput.format(_b);
    var c = cOutput.format(_c);
    writeBlock(gMotionModal.format(0), x, y, z, a, b, c);
  } else {
    forceXYZ();
    var i = ijkFormat.format(_a);
    var j = ijkFormat.format(_b);
    var k = ijkFormat.format(_c);
    writeBlock(gMotionModal.format(0), x, y, z, "I" + i, "J" + j, "K" + k);
  forceFeed();
function onLinear5D(_x, _y, _z, _a, _b, _c, feed) {
    error(localize("Radius compensation cannot be activated/deactivated for 5-axis move."));
    return;
    // get feedrate number
    var f = {frn:0, fmode:0};
    if (a || b || c) {
      f = getMultiaxisFeed(_x, _y, _z, _a, _b, _c, feed);
      if (useInverseTimeFeed) {
        f.frn = inverseTimeOutput.format(f.frn);
      } else {
        f.frn = feedOutput.format(f.frn);
    } else {
      f.frn = feedOutput.format(feed);
      f.fmode = 94;
    if (x || y || z || a || b || c) {
      writeBlock(gFeedModeModal.format(f.fmode), gMotionModal.format(1), x, y, z, a, b, c, f.frn);
    } else if (f) {
      } else {
        writeBlock(gFeedModeModal.format(f.fmode), gMotionModal.format(1), f.frn);
  } else {
    forceXYZ();
    if (x || y || z || i || j || k) {
      writeBlock(gFeedModeModal.format(94), gMotionModal.format(1), x, y, z, "I" + i, "J" + j, "K" + k, f);
    } else if (f) {
      } else {
        writeBlock(gFeedModeModal.format(94), gMotionModal.format(1), f);
// Start of multi-axis feedrate logic
/***** You can add 'properties.useInverseTime' if desired. *****/
/***** 'previousABC' can be added throughout to maintain previous rotary positions. Required for Mill/Turn machines. *****/
/***** 'headOffset' should be defined when a head rotary axis is defined. *****/
/***** The feedrate mode must be included in motion block output (linear, circular, etc.) for Inverse Time feedrate support. *****/
var dpmBPW = 0.1; // ratio of rotary accuracy to linear accuracy for DPM calculations
var inverseTimeUnits = 1.0; // 1.0 = minutes, 60.0 = seconds
var maxInverseTime = 999999.9999; // maximum value to output for Inverse Time feeds
var maxDPM = 9999.99; // maximum value to output for DPM feeds
var useInverseTimeFeed = false; // use 1/T feeds
var inverseTimeFormat = createFormat({decimals:4, forceDecimal:true});
var inverseTimeOutput = createVariable({prefix:"F", force:true}, inverseTimeFormat);
var previousDPMFeed = 0; // previously output DPM feed
var dpmFeedToler = 0.5; // tolerance to determine when the DPM feed has changed
// var previousABC = new Vector(0, 0, 0); // previous ABC position if maintained in post, don't define if not used
var forceOptimized = undefined; // used to override optimized-for-angles points (XZC-mode)
/** Calculate the multi-axis feedrate number. */
function getMultiaxisFeed(_x, _y, _z, _a, _b, _c, feed) {
  if (feed <= 0) {
    error(localize("Feedrate is less than or equal to 0."));
    return f;
  var length = getMoveLength(_x, _y, _z, _a, _b, _c);
  if (useInverseTimeFeed) { // inverse time
    f.frn = getInverseTime(length.tool, feed);
    f.fmode = 93;
    feedOutput.reset();
  } else { // degrees per minute
    f.frn = getFeedDPM(length, feed);
    f.fmode = 94;
  return f;
/** Returns point optimization mode. */
function getOptimizedMode() {
  if (forceOptimized != undefined) {
    return forceOptimized;
  // return (currentSection.getOptimizedTCPMode() != 0); // TAG:doesn't return correct value
  return true; // always return false for non-TCP based heads
/** Calculate the DPM feedrate number. */
function getFeedDPM(_moveLength, _feed) {
  if ((_feed == 0) || (_moveLength.tool < 0.0001) || (toDeg(_moveLength.abcLength) < 0.0005)) {
    return _feed;
  var moveTime = _moveLength.tool / _feed;
  if (moveTime == 0) {
    return _feed;
  var dpmFeed;
  var tcp = false; // !getOptimizedMode() && (forceOptimized == undefined);   // set to false for rotary heads
  if (tcp) { // TCP mode is supported, output feed as FPM
    dpmFeed = _feed;
  } else if (false) { // standard DPM
    dpmFeed = Math.min(toDeg(_moveLength.abcLength) / moveTime, maxDPM);
    if (Math.abs(dpmFeed - previousDPMFeed) < dpmFeedToler) {
      dpmFeed = previousDPMFeed;
  } else if (true) { // combination FPM/DPM
    var length = Math.sqrt(Math.pow(_moveLength.xyzLength, 2.0) + Math.pow((toDeg(_moveLength.abcLength) * dpmBPW), 2.0));
    dpmFeed = Math.min((length / moveTime), maxDPM);
  } else { // machine specific calculation
    dpmFeed = _feed;
  previousDPMFeed = dpmFeed;
  return dpmFeed;
/** Calculate the Inverse time feedrate number. */
function getInverseTime(_length, _feed) {
  var inverseTime;
  if (_length < 1.e-6) { // tool doesn't move
    if (typeof maxInverseTime === "number") {
      inverseTime = maxInverseTime;
    } else {
      inverseTime = 999999;
  } else {
    inverseTime = _feed / _length / inverseTimeUnits;
      if (inverseTime > maxInverseTime) {
  return inverseTime;
/** Calculate radius for each rotary axis. */
function getRotaryRadii(startTool, endTool, startABC, endABC) {
  var radii = new Vector(0, 0, 0);
  var startRadius;
  var endRadius;
  var axis = new Array(machineConfiguration.getAxisU(), machineConfiguration.getAxisV(), machineConfiguration.getAxisW());
  for (var i = 0; i < 3; ++i) {
    if (axis[i].isEnabled()) {
      var startRadius = getRotaryRadius(axis[i], startTool, startABC);
      var endRadius = getRotaryRadius(axis[i], endTool, endABC);
      radii.setCoordinate(axis[i].getCoordinate(), Math.max(startRadius, endRadius));
  return radii;
/** Calculate the distance of the tool position to the center of a rotary axis. */
function getRotaryRadius(axis, toolPosition, abc) {
  if (!axis.isEnabled()) {
    return 0;
  var direction = axis.getEffectiveAxis();
  var normal = direction.getNormalized();
  // calculate the rotary center based on head/table
  var center;
  var radius;
  if (axis.isHead()) {
    var pivot;
    if (typeof headOffset === "number") {
      pivot = headOffset;
    } else {
      pivot = tool.getBodyLength();
    if (axis.getCoordinate() == machineConfiguration.getAxisU().getCoordinate()) { // rider
      center = Vector.sum(toolPosition, Vector.product(machineConfiguration.getDirection(abc), pivot));
      center = Vector.sum(center, axis.getOffset());
      radius = Vector.diff(toolPosition, center).length;
    } else { // carrier
      var angle = abc.getCoordinate(machineConfiguration.getAxisU().getCoordinate());
      radius = Math.abs(pivot * Math.sin(angle));
      radius += axis.getOffset().length;
  } else {
    center = axis.getOffset();
    var d1 = toolPosition.x - center.x;
    var d2 = toolPosition.y - center.y;
    var d3 = toolPosition.z - center.z;
    var radius = Math.sqrt(
      Math.pow((d1 * normal.y) - (d2 * normal.x), 2.0) +
      Math.pow((d2 * normal.z) - (d3 * normal.y), 2.0) +
      Math.pow((d3 * normal.x) - (d1 * normal.z), 2.0)
  return radius;
/** Calculate the linear distance based on the rotation of a rotary axis. */
function getRadialDistance(radius, startABC, endABC) {
  // calculate length of radial move
  var delta = Math.abs(endABC - startABC);
  if (delta > Math.PI) {
    delta = 2 * Math.PI - delta;
  var radialLength = (2 * Math.PI * radius) * (delta / (2 * Math.PI));
  return radialLength;
/** Calculate tooltip, XYZ, and rotary move lengths. */
function getMoveLength(_x, _y, _z, _a, _b, _c) {
  // get starting and ending positions
  var moveLength = {};
  var startTool;
  var endTool;
  var startXYZ;
  var endXYZ;
  var startABC;
  if (typeof previousABC !== "undefined") {
    startABC = new Vector(previousABC.x, previousABC.y, previousABC.z);
  } else {
    startABC = getCurrentDirection();
  var endABC = new Vector(_a, _b, _c);
  if (!getOptimizedMode()) { // calculate XYZ from tool tip
    startTool = getCurrentPosition();
    endTool = new Vector(_x, _y, _z);
    startXYZ = startTool;
    endXYZ = endTool;
    // adjust points for tables
    if (!machineConfiguration.getTableABC(startABC).isZero() || !machineConfiguration.getTableABC(endABC).isZero()) {
      startXYZ = machineConfiguration.getOrientation(machineConfiguration.getTableABC(startABC)).getTransposed().multiply(startXYZ);
      endXYZ = machineConfiguration.getOrientation(machineConfiguration.getTableABC(endABC)).getTransposed().multiply(endXYZ);
    // adjust points for heads
    if (machineConfiguration.getAxisU().isEnabled() && machineConfiguration.getAxisU().isHead()) {
      if (typeof getOptimizedHeads === "function") { // use post processor function to adjust heads
        startXYZ = getOptimizedHeads(startXYZ.x, startXYZ.y, startXYZ.z, startABC.x, startABC.y, startABC.z);
        endXYZ = getOptimizedHeads(endXYZ.x, endXYZ.y, endXYZ.z, endABC.x, endABC.y, endABC.z);
      } else { // guess at head adjustments
        var startDisplacement = machineConfiguration.getDirection(startABC);
        startDisplacement.multiply(headOffset);
        var endDisplacement = machineConfiguration.getDirection(endABC);
        endDisplacement.multiply(headOffset);
        startXYZ = Vector.sum(startTool, startDisplacement);
        endXYZ = Vector.sum(endTool, endDisplacement);
  } else { // calculate tool tip from XYZ, heads are always programmed in TCP mode, so not handled here
    startXYZ = getCurrentPosition();
    endXYZ = new Vector(_x, _y, _z);
    startTool = machineConfiguration.getOrientation(machineConfiguration.getTableABC(startABC)).multiply(startXYZ);
    endTool = machineConfiguration.getOrientation(machineConfiguration.getTableABC(endABC)).multiply(endXYZ);
  // calculate axes movements
  moveLength.xyz = Vector.diff(endXYZ, startXYZ).abs;
  moveLength.xyzLength = moveLength.xyz.length;
  moveLength.abc = Vector.diff(endABC, startABC).abs;
    if (moveLength.abc.getCoordinate(i) > Math.PI) {
      moveLength.abc.setCoordinate(i, 2 * Math.PI - moveLength.abc.getCoordinate(i));
  moveLength.abcLength = moveLength.abc.length;
  // calculate radii
  moveLength.radius = getRotaryRadii(startTool, endTool, startABC, endABC);
  // calculate the radial portion of the tool tip movement
  var radialLength = Math.sqrt(
    Math.pow(getRadialDistance(moveLength.radius.x, startABC.x, endABC.x), 2.0) +
    Math.pow(getRadialDistance(moveLength.radius.y, startABC.y, endABC.y), 2.0) +
    Math.pow(getRadialDistance(moveLength.radius.z, startABC.z, endABC.z), 2.0)
  // calculate the tool tip move length
  // tool tip distance is the move distance based on a combination of linear and rotary axes movement
  moveLength.tool = moveLength.xyzLength + radialLength;
  // debug
  if (false) {
    writeComment("DEBUG - tool   = " + moveLength.tool);
    writeComment("DEBUG - xyz    = " + moveLength.xyz);
    var temp = Vector.product(moveLength.abc, 180/Math.PI);
    writeComment("DEBUG - abc    = " + temp);
    writeComment("DEBUG - radius = " + moveLength.radius);
  return moveLength;
// End of multi-axis feedrate logic
function onCircular(clockwise, cx, cy, cz, x, y, z, feed) {
    error(localize("Radius compensation cannot be activated/deactivated for a circular move."));
    return;
  var start = getCurrentPosition();
  if (isFullCircle()) {
    if (properties.useRadius || isHelical()) { // radius mode does not support full arcs
      linearize(tolerance);
      return;
    switch (getCircularPlane()) {
    case PLANE_XY:
      writeBlock(gFeedModeModal.format(94), gAbsIncModal.format(90), gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), iOutput.format(cx - start.x, 0), jOutput.format(cy - start.y, 0), getFeed(feed));
      break;
    case PLANE_ZX:
      writeBlock(gFeedModeModal.format(94), gAbsIncModal.format(90), gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), iOutput.format(cx - start.x, 0), kOutput.format(cz - start.z, 0), getFeed(feed));
      break;
    case PLANE_YZ:
      writeBlock(gFeedModeModal.format(94), gAbsIncModal.format(90), gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), jOutput.format(cy - start.y, 0), kOutput.format(cz - start.z, 0), getFeed(feed));
      break;
    default:
  } else if (!properties.useRadius) {
    case PLANE_XY:
      writeBlock(gFeedModeModal.format(94), gAbsIncModal.format(90), gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), iOutput.format(cx - start.x, 0), jOutput.format(cy - start.y, 0), getFeed(feed));
      break;
    case PLANE_ZX:
      writeBlock(gFeedModeModal.format(94), gAbsIncModal.format(90), gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), iOutput.format(cx - start.x, 0), kOutput.format(cz - start.z, 0), getFeed(feed));
      break;
    case PLANE_YZ:
      writeBlock(gFeedModeModal.format(94), gAbsIncModal.format(90), gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), jOutput.format(cy - start.y, 0), kOutput.format(cz - start.z, 0), getFeed(feed));
      break;
    default:
  } else { // use radius mode
    var r = getCircularRadius();
    if (toDeg(getCircularSweep()) > 180) {
      r = -r; // allow up to <360 deg arcs
    case PLANE_XY:
      writeBlock(gFeedModeModal.format(94), gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), "R" + rFormat.format(r), getFeed(feed));
      break;
    case PLANE_ZX:
      writeBlock(gFeedModeModal.format(94), gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), "R" + rFormat.format(r), getFeed(feed));
      break;
    case PLANE_YZ:
      writeBlock(gFeedModeModal.format(94), gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), "R" + rFormat.format(r), getFeed(feed));
      break;
    default:
var currentCoolantMode = COOLANT_OFF;
var coolantOff = undefined;
var firstThrough = true;
var addDwell = false;
function setCoolant(coolant) {
  var coolantCodes = getCoolantCodes(coolant);
  if (Array.isArray(coolantCodes)) {
    if (singleLineCoolant) {
      writeBlock(coolantCodes.join(getWordSeparator()));
    } else {
      for (var c in coolantCodes) {
        writeBlock(coolantCodes[c]);
    return undefined;
  return coolantCodes;
function getCoolantCodes(coolant) {
  var multipleCoolantBlocks = new Array(); // create a formatted array to be passed into the outputted line
  if (!coolants) {
    error(localize("Coolants have not been defined."));
  if (isProbeOperation()) { // avoid coolant output for probing
    coolant = COOLANT_OFF;
  if (coolant == currentCoolantMode) {
    return undefined; // coolant is already active
  if ((coolant != COOLANT_OFF) && (currentCoolantMode != COOLANT_OFF)) {
    if (Array.isArray(coolantOff)) {
      for (var i in coolantOff) {
        multipleCoolantBlocks.push(mFormat.format(coolantOff[i]));
    } else {
      multipleCoolantBlocks.push(mFormat.format(coolantOff));
  var m;
  var coolantCodes = {};
  for (var c in coolants) { // find required coolant codes into the coolants array
    if (coolants[c].id == coolant) {
      coolantCodes.on = coolants[c].on;
      if (coolants[c].off != undefined) {
        coolantCodes.off = coolants[c].off;
        break;
      } else {
        for (var i in coolants) {
          if (coolants[i].id == COOLANT_OFF) {
            coolantCodes.off = coolants[i].off;
            break;
  if (coolant == COOLANT_OFF) {
    m = !coolantOff ? coolantCodes.off : coolantOff; // use the default coolant off command when an 'off' value is not specified
  } else {
    coolantOff = coolantCodes.off;
    m = coolantCodes.on;
  if (!m) {
    onUnsupportedCoolant(coolant);
    m = 9;
  } else {
    if (Array.isArray(m)) {
      for (var i in m) {
        multipleCoolantBlocks.push(mFormat.format(m[i]));
    } else {
      multipleCoolantBlocks.push(mFormat.format(m));
    currentCoolantMode = coolant;
    return multipleCoolantBlocks; // return the single formatted coolant value
  return undefined;
var mapCommand = {
  COMMAND_STOP:0,
  COMMAND_OPTIONAL_STOP:1,
  COMMAND_END:2,
  COMMAND_SPINDLE_CLOCKWISE:3,
  COMMAND_SPINDLE_COUNTERCLOCKWISE:4,
  COMMAND_STOP_SPINDLE:5,
  COMMAND_ORIENTATE_SPINDLE:19
function onCommand(command) {
  switch (command) {
  case COMMAND_STOP:
    writeBlock(mFormat.format(0));
    forceSpindleSpeed = true;
    return;
  case COMMAND_START_SPINDLE:
    onCommand(tool.clockwise ? COMMAND_SPINDLE_CLOCKWISE : COMMAND_SPINDLE_COUNTERCLOCKWISE);
    return;
  case COMMAND_LOCK_MULTI_AXIS:
    return;
  case COMMAND_UNLOCK_MULTI_AXIS:
    return;
  case COMMAND_START_CHIP_TRANSPORT:
    return;
  case COMMAND_STOP_CHIP_TRANSPORT:
    return;
  case COMMAND_BREAK_CONTROL:
    return;
  case COMMAND_TOOL_MEASURE:
    return;
  var stringId = getCommandStringId(command);
  var mcode = mapCommand[stringId];
  if (mcode != undefined) {
    writeBlock(mFormat.format(mcode));
  } else {
    onUnsupportedCommand(command);
function onSectionEnd() {
    writeBlock(gFeedModeModal.format(94)); // inverse time feed off
  if (currentSection.isMultiAxis() && !currentSection.isOptimizedForMachine()) {
    writeBlock(gFormat.format(49));
  if (((getCurrentSectionId() + 1) >= getNumberOfSections()) ||
      (tool.number != getNextSection().getTool().number)) {
    onCommand(COMMAND_BREAK_CONTROL);
  if (!isProbeOperation() && properties.washdownCoolant == "operationEnd") {
    writeBlock(mFormat.format(washdownCoolant.off));
  if (!isLastSection() && (getNextSection().getTool().coolant != tool.coolant)) {
  forceAny();
/** Output block to do safe retract and/or move to home position. */
function writeRetract() {
  if (arguments.length == 0) {
    error(localize("No axis specified for writeRetract()."));
    return;
  var words = []; // store all retracted axes in an array
  for (var i = 0; i < arguments.length; ++i) {
    let instances = 0; // checks for duplicate retract calls
    for (var j = 0; j < arguments.length; ++j) {
      if (arguments[i] == arguments[j]) {
        ++instances;
    if (instances > 1) { // error if there are multiple retract calls for the same axis
      error(localize("Cannot retract the same axis twice in one line"));
      return;
    switch (arguments[i]) {
    case X:
      if (machineConfiguration.hasHomePositionX()) {
        words.push("X" + xyzFormat.format(machineConfiguration.getHomePositionX()));
      break;
    case Y:
      if (machineConfiguration.hasHomePositionY()) {
        words.push("Y" + xyzFormat.format(machineConfiguration.getHomePositionY()));
    break;
    case Z:
      writeBlock(gFormat.format(28), gAbsIncModal.format(91), "Z" + xyzFormat.format(machineConfiguration.getRetractPlane())); // retract
      writeBlock(gAbsIncModal.format(90));
      retracted = true; // specifies that the tool has been retracted to the safe plane
      zOutput.reset();
      break;
    default:
      error(localize("Bad axis specified for writeRetract()."));
      return;
  if (words.length > 0) {
      writeBlock(gAbsIncModal.format(90), gFormat.format(53), words); // retract
function onClose() {
  writeln("");
  if (!isProbeOperation() && (properties.washdownCoolant == "always") || properties.washdownCoolant == "programEnd") {
    if (properties.washdownCoolant == "programEnd") {
  // reload first tool (handles retract)
  writeBlock(gFormat.format(100), "T" + toolFormat.format(getSection(0).getTool().number));
  writeBlock(gFormat.format(53), "X" + xyzFormat.format(-20), "Y" + xyzFormat.format(0)); // TAG: is this position the default position on Brother machines?
  setWorkPlane(new Vector(0, 0, 0)); // reset working plane
  writeRetract(X, Y);
  onImpliedCommand(COMMAND_END);
  onImpliedCommand(COMMAND_STOP_SPINDLE);
  writeBlock(mFormat.format(30)); // stop program, spindle stop, coolant off
andrea.amilo
Hi @wotdesigns ,
1st:
I think you could write this code to add from tool change 17 a line call N17 ( from line 885 ) :
    if ( tool.number >= 17 ) {
      writeBlock("N" + toolFormat.format(tool.number));
2nd:
You could add this code ( starting from line 2453 ) to write G100 T current tool number :
  forceAny();
  if (!isLastSection() && (getNextSection().getTool().number != tool.number)) {
    writeBlock(gFormat.format(100), "T" + toolFormat.format(tool.number));
Please test it carefully and let me know. Regards,
Andrea Amilo
Senior Technical Consultant
Autodesk Knowledge Network | Fusion 360 Webinars | Autodesk Make
