Having a really hard time with Carbide 3D and Inventor HSM working. (Shapeoko 3)
Sschram
Sschram
I've tried the genaric tiny post, it loads but my holes are way off after I run it. I've looked online and somewhere said to try using the genaric GRBL but that doesn't even load in Carbide 3D.
Is there a different control program I can use that will work with the Shapeoko 3 or is there a different post processor I should be useing?
Steve
matthew.nichols
Try the attached post.  This should work for you.
Thank you,
Matt
Matthew Nichols
Adoption Specialist - MFG
Sschram
Thank you so much, giving her a try now.
Steve
Hi Matthew,
You're suggesting to try the post processor carbide3d.cps (in ArtCAM for the Carbide 3D ShapeOko 3 CNC).
Can you please elaborate on how to add this to ArtCAM's list of output post processors?  I've searched all around, but cannot find the process of using this .cps file in ArtCAM.
I am currently running the demo version of ArtCAM, but intend to buy a subscription soon, and I would like to generate gcode for the ShapeOko 3 CNC, NOT the Nomad CNC (both are made by Carbide 3D).
Thank you
Steve
Laurens-3DTechDraw
@Anonymous wrote:
Hi Matthew,
Thank you
Steve
@Anonymous this post id for the AutodeskCAM/AutodeskHSM products. SO Fusion360, Inventor HSM and HSMWorks.
ArtCAM has it's own posts processors.
You can find their side of the forum here:
https://forums.autodesk.com/t5/artcam/ct-p/283
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
