HAAS post edit, adding Tool break detection to post
sales
Message 1 of 13
sales
We are using the current generic Haas 3axis mill post.
I’m trying to add tool break detection G65 P9023 A24. H.003 T# , Im harcoding most of it just nned to get the current tool #.
It is almost working except it is taking the wrong T#.
It will take the next tool but I need it to use the current one.
See Line 729
How can we change this?
Please see attached post.
Mike
Replies (12)
Message 2 of 13
One way that may be simpler, is to write a quick macro sub-program that looks at the current tool in the spindle & performs a break check.
One that I have seen online is as following:
O9000;
#100 = #3026; (#3026 = register for current tool in spindle. Assign to #100 which is a visible register)
G53G49Z0M09; (Z-AXIS Safety Retract)
G00G90;
G65P9023A24.T#100H.02; (Renishaw tool breakage routine, H = tolerance of tool +/- compared to set value before alarming)
G103; (Resets block look ahead to default value)
M62; (Turns off touch probe)
M99;
I did not write this, it comes from user "haastec" on the CNC Zone forum.
You could use this, or write a similar program, then alias it to an unused m-code.
Then you can simply have your post insert that M-code at the end of each Operation prior to tool change to probe for breakage.
Good luck,
Steve
Message 3 of 13
sales
I will try that, Thank you!
Message 4 of 13
One other thing I forgot to mention.
Instead of hard-coding in the m-code for tool check on every operation, you can setup your post so when you insert a "manual NC - Tool Break Control", your post will output that M-code for you.
This way, you can do selective break checks on known problem tools.
If you want help implementing that, let me know.
Steve
Message 5 of 13
sales
That's a great idea.
Do you have a post sample that is doing this already?
Thank you.
Message 6 of 13
Sure,
I'll post something tomorrow. I didn't bring my computer home tonight.
Steve
Message 7 of 13
Give this a look.
I wrote it into the post you provided above.
Every time you place a Manual NC - Tool Break Control, it will call an M-code.
Currently i set it to M100, but you can pick whatever you like.
One note: this only works properly if placed after all operations for the tool you are using are completed.
If you need to break check a tool, then continue using that same tool, please place a "Manual NC - Force tool change" right after the break control.
If you search thru the post for my last name "Piche", you will find where I made edits.
Let me know if you have any questions.
Steve
Message 8 of 13
sales
Looks great, Thank you so much!
I will give everything a try shortly.
Mike
Message 9 of 13
Glad I could help.
Achim gave me pointers on adding this a couple years ago, so I figure I should "pay it forward".
Let me know if you have any questions or need anything else.
Steve
Message 10 of 13
sales
One question, how do you turn it off?
Let say I have 10 operations, and I turn it on after operation 5 by inserting "Manual NC Tool break control" it will stay on till op 10.
Would we need to add a new  Type: Tool break OFF?
Thank you.
Message 11 of 13
Oops, my error.
Try this one.
I had a capital letter where I should of had a lowercase.
Message 12 of 13
sales
Great it all works including the Haas macro.
Thank you!Smiley Happy
Message 13 of 13
sales
I noticed if we Pattern a tool path (order by tool ) it puts a M100 even if it just move over to the next pattern.
Which would be a problem because the spindel would not be running after the macro.
This might be more complex to fix.
Thank you.
Mike
