HSM Post Processor Forum
Haas MiniMill Post output Error
5 REPLIES 5
Eli_Dexter
151 Views, 5 Replies
I have just got new Hass MiniMill machine, downloaded Post for Hass (tried NGC, Pre-NGC, and some other) and trying to post. 1st thing I have noticed Program Settings is all blank.
When I click Post, I am getting error message:
Error: Failed to evaluate post configuration.
Loading locale from 'C:\Program Files\HSMWorks\locales\english_us.xml'
Code page changed to '1252 (ANSI - Latin I)'
Start time: Thursday, December 12, 2024 8:33:08 PM
Code page changed to '20127 (US-ASCII)'
Warning: Unsupported format specifier 'minDigitsLeft'.
Error: ReferenceError: FORMAT_REAL is not defined
Error at line: 296
Stack dump:
@K:\Engineering\ACAD\SolidWorks\SSDI Library\HSMXpress\haas.cps:295
Failed while processing global script.
Is there a problem with post or I am doing something wrong? I have used other posts (for different machines) and they are fine...
Tags (3)
Labels (1)
5 REPLIES 5
CNC_Lee
in reply to: Eli_Dexter
@Eli_Dexter
Can you share the file that you are getting the error with?
If my post answers your question, please use Accept as Solution.
CNC Lee
Autodesk CAM Post Processor Expert
https://linktr.ee/cnclee
Eli_Dexter
Here you are... But I do not believe the issue is in the file. I had another file that gave me the same error.
CNC_Lee
@Eli_Dexter
Got you!
I was more so looking for the CAM related information in the file.
Please store your toolpaths using the "Save as Template" function and attach a copy of that as well.
CNC Lee
Eli_Dexter
in reply to: CNC_Lee
See Attached. I had to rename the file to .xml - otherwise I would not be abple to attach it. Please download and rename it to .hsmworks-template.
Eli_Dexter
I still did not get any replies to my las post.
Any ideas?
