HAAS A-Axsis post - Not NGC (generic)
Hello.
Have a 4 year old HAAS VF 4 SS with A-axsis. Have been using the Post for this that always come with the latest updates of Fusion 360. Unfortunately I made a big mistake with not saving this post as a separate file. Now fusion updates all HAAS post with pre-NGC posts. This post seems not to work properly when posting the code.
I use pattern, and at the end of the program it should post code for tool change to new tool etc - but this seems to be missing in the code from PRE NGC post
How can I get the last post processor thats made - not for Pre NGC?? or can the new post be improved to also work for machines without NGC control??
Are there are place where all version of post are stored?
Below code posted with new and old PP:
This is code from OLD post Processor:
(Frifresing-63mm)
N17650 M9
N17655 T12 M6
(Skivefres-DC63.0-CDX21.0-Steel)
N17660 M88
N17665 S985 M3
N17670 G154 P1
N17675 M11
N17680 G0 A0.
N17685 M10
N17695 G0 X25.95 Y-84.33
N17700 G43 Z151.329 H12
N17705 T1
N17710 G0 Z128.429
N17715 G1 Z125.429 F157.
N17725 G41 X-8.7 Y-85.33 D12 F100.
N17730 Y-130.33
N17735 Y-217.73
N17745 G40 X25.95 Y-218.73 F157.
N17750 G0 Z151.329
N17755 M5
N17760 G53 G0 Z0. (It returns the tool to Z0. before new tool change and operation)
(Planing)
N17770 M89
N17775 T1 M6 (code for next tool and toolcahnge command?
N17780 M88
N17785 S1687 M3
N17790 G154 P1
N17795 M11
N17800 G0 A0.
N17805 M10
N17815 G0 X9.5 Y-85.33
N17820 G43 Z140.329 H1
N17825 T18
N17830 G0 Z130.329
N17835 G1 Z126.329 F1500.
N17840 Z124.329
N17850 G41 X-18. Y-90.33 D1 F800.
N17855 Y-212.73
N17865 G40 X9.5 Y-217.73 F1500.
N17870 G0 Z140.329
N17875 M5
N17880 G53 G0 Z0.
Code from new PP:
(Frifresing-63mm)
N17650 M9
N17655 T1 M6
(Skivefres-DC63.0-LU-3.0mm-CDX21.0-Steel)
N17660 M88
N17665 S1036 M3
N17670 G154 P1
N17675 M11
N17680 G0 A0.
N17685 M10
N17695 G0 X25.75 Y-84.33
N17705 T18
N17710 G0 Z128.429
N17715 G1 Z124.429 F165.
N17725 G41 X-8.9 Y-85.33 D1
N17730 Y-130.33 F165.72
N17735 Y-217.73
N17745 G40 X25.75 Y-218.73 F165.
N17750 G0 Z151.329
(M01) (this is manual NC code comment insert. As you see the tool are not retracted to Z0. before new operation and the code for tool change to new tool are missing below.)
(Planing)
N17755 S1687 M3   (code for next tool and toolcahnge command are missing in the code?
N17760 G0 X9.5 Y-85.33
N17765 Z140.329
N17770 Z130.329
N17775 G1 Z126.329 F1500.
N17780 Z124.329
N17790 G41 X-18. Y-90.33 D1 F800.
N17795 Y-212.73
N17805 G40 X9.5 Y-217.73 F1500.
N17810 G0 Z140.329
N17815 M5
N17820 G53 G0 Z0.
AchimN
What i noticed first is that your old output starts by using Tool #12, where your new output starts by using Tool #1.
Can you please share your fusion file including toolpathes?
Achim.N
Principal Technology Consultant
I made a mistake in the cam tree - by having same tool number on two operations following each other.
I changed the tool number and it all worked fine.
