Grbl laser post
Grbl laser post
Grbl laser post
I would like to request a post for grbl controlled laser machines. It would be nice if the power setting values were editable considering the pwm range is adjustable in the firmware depending on the spindle type.
Tim
Laurens-3DTechDraw
I see you found the smoothie to be working for you.
You can always have a read here to learn how to make edits to your post to fully suit your needs: https://forums.autodesk.com/t5/post-processors/help-my-post-processor-needs-to-be-edited-now-what/td...
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
dregalia2014
I have  GRBL setup, and tried using smoothie, however mine is failing at this point:
Vendor url: http://smoothieware.org
Legal: Copyright (C) 2012-2015 by Autodesk, Inc.
Post processor signature could not be verified (error 0xfffffffc).
Generated by: Fusion 360 CAM 2.0.1957
Error: Radius compensation mode is not supported.
Stop time: Tuesday, April 12, 2016 12:40:03 AM
Post processing failed.
Any thoughts on how to get past this?
Set compensation to in computer and not in control. This will fix the problem.
Later
Tim
dregalia2014
Worked like a charm
