G95 / G94 in properties.menu
mbTRAAF
Message 1 of 11
mbTRAAF
Good morning all,
unfortunately our Mazak postprocessor lacks the possibility to switch between G94 and G95.
I have seen on various Fanuc postprocessors that there is the possibility to choose.
Could someone help us do this?
Replies (10)
Message 2 of 11
boopathi.sivakumar
@mbTRAAF
I think you can copy and paste the codes from fanuc it will work
just all you need to do is find useG95 in the fanuc post and you have copy and paste the codes in mazak  in the same location.
You can use the vs code to make the edit easier
https://forums.autodesk.com/t5/hsm-post-processor-forum/technical-faq/td-p/7473258
The above link will help you some of the contents before you need to edit
If you have problems with the modified post just poke here
Boopathi Sivakumar
Senior Technology Consultant
Message 3 of 11
mbTRAAF
Hi there,
since Fanuc and Mazak are not exactly the same, I think it won't work that way.
I copied all entries except for the G95 in rigid tapping.
Rigid tapping should be with Mazak G84.3 & G84.2 ......
I attached the changed post as requested!
Unfortunately it doesn't work that way ........
Should you make an answer to this contribution, I would like to ask you to use the above postprocessor as a template.
I would be very happy about answers .....
Message 4 of 11
mbTRAAF
in a quiet minute I managed it now.
Now I have found that the feeds are unfortunately not entered in the parameter feeds.
An error message is thrown out that the machine does not support this.
The machine drives this without problems.
I would be grateful for support
Message 5 of 11
boopathi.sivakumar
@mbTRAAF
This is because at the moment it won't support the both but you can do some tweaks to make it work
go this place and block it
  // if (properties.useG95 && properties.useParametricFeed) {
  //   error(localize("Parametric feed is not supported when using G95."));
  //   return;
  if (properties.useG95) {
this is line which is throwing the error
and in the function getFeed(f) add change something like this below
function getFeed(f) {
  if (properties.useG95&& !properties.useParametricFeed) {
    return feedOutput.format(f / spindleSpeed); // use feed value
  if (activeMovements) {
and in the
function initializeActiveFeeds() at the end made some changes like this
  for (var i = 0; i < activeFeeds.length; ++i) {
    var feedContext = activeFeeds[i];
    if(properties.useG95){
      writeBlock("#" + (firstFeedParameter + feedContext.id) + "=" + feedFormat.format(feedContext.feed/spindleSpeed), formatComment(feedContext.description));
    }else{
      writeBlock("#" + (firstFeedParameter + feedContext.id) + "=" + feedFormat.format(feedContext.feed), formatComment(feedContext.description));
var currentWorkPlaneABC = undefined;
function forceWorkPlane() {
Save and test the file carefully
Boopathi Sivakumar
Message 6 of 11
mbTRAAF
Thanks for the quick answer !!!!
Message 7 of 11
mbTRAAF
Hi Mr. Boopathi,
Unfortunately there is still a mistake in the postprocessor.
This is already available in the post processor of the first article.
And he just throws me a parameter feed (# ...) or F ...... feed.
According to the programs, there are several that have to be called up.
It does not matter whether parameter feed or G95 is activated in the properties menu or not Enclosed the currently
adapted post processor.
Message 8 of 11
mbTRAAF
Thanks for the PM,
and apologize that I'm only now reporting.
So the problem that exists is this:
Only one feed is written out in both parameter and normal feed output (F). (See program 1000)
However, several feeds are called up in the program and these should also remain available. (# 101, # 102, # 103 ect. See also F - feeds)
Now I would like to ask that these be output as in Program 2000.
Many thanks
Message 9 of 11
mbTRAAF
Here are the Programms.
Message 10 of 11
boopathi.sivakumar
@mbTRAAF
You have removed the this line
While copy pasting things
go this section by searching
and add the line in red your final code will be like this
    }else{
It will work now
Boopathi Sivakumar
Message 11 of 11
mbTRAAF
Thank you very much for your effort and your patience
