G254 and 55 code not posting
I am using the Haas generic Trunnion post and having issues with the post outputting a G254 and 55 code, they seem to be nonexistent in the post, is there anything I need to change in the post configuration to make these codes post?
I don't think that post is setup for DWO commands.
Maybe try the Generic Haas - Next Generation Post here:
http://cam.autodesk.com/posts/
It looks like that post can be configured easily to setup your trunnion, and supports G254/G255
Steve
AchimN
That´s correct, only the UMC750 and nextgen control haas posts are using DWO.
Achim.N
Principal Technology Consultant
Hello, You can use next generation post and in the edit section(bottom right) while posting just enable A and B axis.
