Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Semus wrote:
It's using G28, which apparently tells the machine to return to it's reference point. But, isn't the reference point zero/zero and not "home"?
I have a similar issue (somewhat). when I start a new job on my cnc, after specifying the origin (and the machine would start cutting normally), it goes home and indicates that the job is complete without cutting anything. this has happened previously and I would simply re-create the file and the gcode and everything would work. I have tried re-creating the file and generating the gcode several times but always the same results. I have attached both the fusion and the gcode file. any idea what I am doing wrong?
