HSM Post Processor Forum
Fusion360 PP needs to change
1 REPLY 1
kanokwan25310104
58 Views, 1 Reply
Hello experts,
I need some one help me to change the code as following,
I need the PP likes this.
O1001
(T3 D=8. CR=0. - ZMIN=-20. - FLAT END MILL)
G90 G94 G17 G49 G40 G80
G21
G28 G91 Z0.
(2D CONTOUR1)
N1 T3 M06
S3000 M03
G54G90G00 X1. Y32.  (need to put WCS and G90 this line)
G43 Z50. H03
G04 X4.0 ( Need to put G04 X5.0 this line)
G00 Z6. M08  (Need to put M08 this line)
G01 Z2. F333.
cutting program
G00 Z10.0 M09 ( Need M09 before go to ZRN)
G91G28Z0
M05
M01
Please advise.
Thank you in advance.
1 REPLY 1
Hello @kanokwan25310104 ,
I've tried to tune your post as you requested.
Please try following these steps:
1- Add coolant-off command to line 484:
2- Remove G90 code from line 512. This is the new edited line:
3- Add G04 code and move coolant command to lines 537 and 538, as shown below:
4- Remove coolant-off command from line 1523:
5- Add G90 command to the existing line 2757:
You should get an output very similar (not exactly identical, but working in my opinion) to what you requested.
Please test it carefully and let me know.
Andrea Amilo
Senior Technical Consultant
Autodesk Knowledge Network | Fusion 360 Webinars | Autodesk Make
