Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Fusion 360 CAM post for Roland MDX-540 A axis (4th Axis)
I can't find a post processor which supports the 4th axis to our Roland MDX 540 machines.
Any ideas on where I go from here?
Best,
Will
matty.fuller
You just need to enable multi-axis in the post... attached post has the A axis enabled and works fine on our machine in NC mode. I haven't bothered getting the A axis enabled in an RML post as I prefer ISO.
FYI a search of the forum would've found you this answer.
FYI #2 for making changes to posts & enabling multi-axis, see pinned topics for Technical FAQ: https://forums.autodesk.com/t5/hsm-post-processor-forum/technical-faq/td-p/7473258
wreed6
Observer
Observer
Will your kindly provided A axis enabled Roland iso post work with my Roland MDX650 with ZCL-650 rotating A axis and 4 bay tool changer?
I am extremely unfamiliar with editing post processor files and somewhat nervous to do so. I will read over the pinned topics from the link you provided asap.
I never would have thought that one could just enable the A axis, where was this change in the post processor file accomplished at?
It has been an ongoing search for years to find a means to run the 650 with the indexed rotating axis, it would be a complete game changer for me if I could finally accomplish CAM operations as such. Especially if it is accomplishable with Fusion 360 or even Solidworks Cam(threw HSMWorks).
matty.fuller
I don't have access to an MDX 650 so can't comment on whether it will work or not - if your 4th axis rotates around X it should work fine, but test it carefully. You may need to ensure the setup origin is on the rotational axis, I forget as it's been a while since I used that machine.
As per previous post, consult the pinned FAQ topic for info on enabling or adjusting 4/5 axis in your post:
https://forums.autodesk.com/t5/hsm-post-processor-forum/how-to-set-up-a-4-5-axis-machine-configurati...
wreed6
Observer
Observer
I really appreciate the info and direct link to the 4/5 axis FAQ. It would seem the wall I am hitting is the post generates with Y and A specified at the same time. Where if specifying Y axis and A axis within the same block results in a error. The ZCL650 can only operate in XYZ or XZA simultaneously according to the documentation.
It may just be an setup struggle I am having with Fusion 360, but no matter what I did for orientations, I couldn't seem to get the post to generate without using the Y axis. Oddly it generated using Y where I would have expected X to been utilized.
