Force C-axis output for radial drilling in mill/turn Okuma lathe
cyltech
cyltech
We have an Okuma LB-15IIM mill/turn lathe that we have a working post-processor for, modified from an older version of the stock Autodesk post for Okuma LB-3000
I have a problem with that post, since the OSP-7000L control requires G181/G183 radial drilling cycles (drilling on the side of workpieces) to have C-axis value outputs in the same line as G181/G183 cycle calls.
Live-tool drilling radially (on the face of workpieces) does output C-axis values normally, but I cannot figure out where the post-processor is getting those values and apply a similar code to output C-values on side drilling.
Even the current version of the Okuma LB-3000 post only outputs C-values on axial and not radial drilling, clearly reproducible through the visual studio code post-processor extension mill-turn demo programs.
Can anyone help me out with the default LB-3000 post to get the C-axis values to output?
BrandonTBFBF
Take a look at the getCommonCycle function inside of this post:
https://forums.autodesk.com/t5/hsm-post-processor-forum/okuma-lb3000-post-inside/td-p/9717088
I've put a lot of work into this to make it "okuma friendly". Might be a good starting point for 7000 control post
cyltech
Thanks, I copied the getCommonCycle from your latest post in that thread and it worked.
The only things I had to change were:
1) Remove the "conditional(useM136, mFormat.format(136))"
2) Change plane from 19 to 18, since the LB15-IIM doesn't have plane 19 and I've changed other post designations to reflect that
Thanks a bunch!
