Flexicam post processor
gvidasss
gvidasss
Community Visitor
Community Visitor
Hi.I'm using it now Artcam software and i want to go to FUSION 360.I use flexicam cnc and can't find it post processor standard does not work.Maybe someone face similar problem and can help me
I'm adding what I still use:
; Eckelmann configuration file
; History
; Who When What
; HS 10/06/2011 Written
DESCRIPTION = "FlexiCAM ACS C Achse tangential (*.din)"
FILE_EXTENSION = "din"
UNITS = MM
; Cariage return - line feed at end of each line
END_OF_LINE = "[13][10]"
; Block numbering
LINE_NUM_START = 0
LINE_NUM_INCREMENT = 10
LINE_NUM_MAXIMUM = 999999
; Set up default formating for variables
; Line numbering
FORMAT = [N|@|N|1.0]
; Spindle Speed
FORMAT = [S|@| E|1.0]
; Feed Rate
FORMAT = [F|#| F|1.0]
; Tool moves in x,y and z
FORMAT = [X|#| X|1.3]
FORMAT = [Y|#| Y|1.3]
FORMAT = [Z|#| Z|1.3|1]
; Arc Centre Cordinates
FORMAT = [I|@| I|1.3]
FORMAT = [J|@| J|1.3]
; Home tool positions
FORMAT = [XH|@| X|1.3]
FORMAT = [YH|@| Y|1.3]
FORMAT = [ZH|@| Z|1.3|1]
; Set up program header
START = "%1000"
START = "G17"
START = "G90"
START = "M110"
START = "M112"
START = "M6 T[T]"
START = "M120"
START = "M122"
START = "S1"
START = "M3[S]"
START = "M42 (Korrekturmodul an)"
START = "M100"
; Program moves
RAPID_RATE_MOVE = "M15[13][10]G0[X][Y][Z][13][10]M14"
FIRST_FEED_RATE_MOVE = "G1[X][Y][Z][F] "
FEED_RATE_MOVE = "[X][Y][Z][F]"
TOOLCHANGE = "G40"
TOOLCHANGE = "M101"
TOOLCHANGE = "M6 T[T]"
TOOLCHANGE = "M122"
TOOLCHANGE = "G0[XH][YH]"
TOOLCHANGE = "M3[S]"
TOOLCHANGE = "G0[ZH]"
TOOLCHANGE = "M42"
TOOLCHANGE = "M100"
FIRST_CW_ARC_MOVE = "G2[X][Y][I][J][F] "
CW_ARC_MOVE = "G2[X][Y][I][J]"
FIRST_CCW_ARC_MOVE = "G3[X][Y][I][J][F]"
CCW_ARC_MOVE = "G3[X][Y][I][J]"
; End of file
END = "M15"
END = "G40 (Korrekturmodul aus)"
END = "M101"
END = "M5 (Spindel aus)"
END = "M123 (Absaugung hoch)"
END = "M121"
END = "M113"
END = "M111"
END = "M30"
Arun.rs
HI @gvidasss ,
Fusion library does have a Flexicam post available, which is generic. Based on the ARTCAM post you shared, it appears to use some special codes in the program start, end, and also during rapid movements.
You will likely need to modify the post-processor to suit your specific requirements. Here is a link that explains how to make post modifications.
Alternatively, you can reach out to one of our CAM partners through the Service Marketplace, who can assist in creating a customised post for your specific machine setup.
Regards
Arun
If my post answers your question, please click the 'Accept Solution' button. This helps everyone find answers more quickly!
Arun.RS
Senior Technology Consultant
CNC_Lee
@gvidasss
If the generic FlexiCAM post is not providing the required output, I offer post processor development services and happy to work out a solution for your machine! Please message me if still needing assistance.
If my post answers your question, please use Accept as Solution.
CNC Lee
Autodesk CAM Post Processor Expert
