I am working with Inventor Cam, and am having a couple issues.
1. I downloaded a post from the Autodesk Machine Library:
Machine: HAAS VF-3YT/50
Control/Post: HAAS (Pre-NGC)
Minimum revision:45909
The downloaded file extension is .CPSZ, it does not open in a text editor cleanly, it is like it is encrypted, just a bunch of random symbols. I've tried just changing the extension to .cps or .txt, but nothing changes. Is there a way I can edit these posts?
2. More specifically about changing a post, is there a way to eliminate the posting of "N" Sequence Numbers (N10, N15, N20, etc...) on each line of the code. I have both the increment and start number both set to 0 in the post process window, and all that does is put "N0" in front of each line. I don't want the N numbers at all.
3. I know this is a "Post Processor Forum," but I see how Fusion360 has a lot more toolpaths and more control over those toolpaths. Why does Inventor Cam not get these updates? Seems like Fusion360 gets all the goodies. I have a large library of Inventor files, I cannot switch to Fusion360.
