HSM Post Processor Forum
FANUC Post processing fail!!!
15 REPLIES 15
Message 1 of 16
pavlinbg
804 Views, 15 Replies
Hello!
Some times I have a problem with postprocesor FANUC.cps on version HSMWORKS 2012 R5.
I working with 3-axis.
I have this massage: "Warning: Work offset has not been specified. Using G54 as WCS."
In older version HSMWORK 2012 R1 all works fine without problems on any operations when i posting.
Can you help me to fix this problem?
15 REPLIES 15
Message 2 of 16
This is not a post processing fail.
It's just an extra warning that you haven't specified a work offset in your job.
So it tells you it will use G54 because that's it's best bet.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Message 3 of 16
In MY JOB basic folder I choosing offset value: 0 (default value is G54) , other values 1 (G54), 2 (G55), 3 (G56), 4 (G57), 5 (G58), 6 (G59).
I tried with other values, but same result of error masage!
Before I tried to take file POST.DLL from older version and replace it with the newer version and no error masage, but every time when I start SOLIDWORKS I have warning masage window and I click on OK button and all is alright.
I want to make it without replacing this file to fix this problem. Any body know how to fix it? 😞
Message 4 of 16
Can you make a screencast so we can see what is going on?
Also is there a reason you aren't on HSMWorks 2017?
Laurens Wijnschenk
3DTechDraw
René for Legend.
Message 5 of 16
OK tomorow I will make screenshot and I will post here!
The reason I use SOLIDWORKS 2014 and HSMWORKS 2017 do not working on this version, also SOLIDWORKS 2014 doing good work for me.
Message 6 of 16
patrik_stellgren
in reply to: pavlinbg
No, not screenshot.
A screencast  ->  https://knowledge.autodesk.com/community/screencast
Message 7 of 16
pavlinbg
in reply to: patrik_stellgren
I typing from my home and I use MAC OS X operation system and I can't use SCREENCAST!
Today in my work I tried with HSMWORKS 2014, but it show me the same error!
I find the problem! I thinк that POST.EXE is buged (corrupted).
Can you tell me what is mean this error massage?
Now I paste the error  message:
"Information: Configuration: Generic FANUC
 Information: Vendor: HSMWorks ApS
 Information: Posting intermediate data to 'D:\1. SHISHETA BURKANI KENOVE\03. March 2017\VETREN YONCHO 330ml\1111.NCC'
 Information: Total number of warnings: 2
 Error: Failed to post intermediate NC data.
 Loading locale from 'C:\Program Files\HSMWorks\locales\english_us.xml'
 Code page changed to '1251  (ANSI - Cyrillic)'
 Start time: Monday, March 13, 2017 9:49:58 AM
 Warning(C:\Program Files\HSMWorks\posts\FANUC (RAIS M400) FINISH.cps:250): octal literals and octal escape sequences are deprecated
 Code page changed to '20127 (US-ASCII)'
 Post processor engine: 3.9.7 37328
 Configuration path: C:\Program Files\HSMWorks\posts\FANUC (RAIS M400) FINISH.cps
 Include paths: C:\Program Files\HSMWorks\posts
 Configuration modification date: Monday, March 13, 2017 9:48:11 AM
 Output path: D:\1. SHISHETA BURKANI KENOVE\03. March 2017\VETREN YONCHO 330ml\1111.NCC
 Checksum of intermediate NC data: fa3375437f2ff1ac0a96c57a897d9570
 Checksum of configuration: cc55617cd6f706c00df7d0969a73ac94
 Vendor url: http://www.hsmworks.com
 Legal: Copyright (C) 2007-2012 HSMWorks ApS
 Generated by: HSMWorks 2014 R3.37650
 Error: Error: The installation has been corrupted. Please reinstall and reactivate your license to correct the problem.
 Stack dump:
 onCorruption()@:5157
 Failed while processing onLinear() for record 359.
 Error: Failed to invoke function 'onCorruption'.
 Error: Failed to invoke 'onLinear' in the post configuration.
 Stop time: Monday, March 13, 2017 9:49:58 AM
 Post processing failed."
Thanks!
Message 8 of 16
 Stack dump:
Thanks!
Alright.
So like expected the work offset warning isn't the problem.
It errors out on the OnCorruption Function.
Is your license valid for the HSMWorks 2012 R5 release?
Laurens Wijnschenk
3DTechDraw
René for Legend.
Message 9 of 16
I don't know! The license is valid to 2019 year!
I use the same license file in HSMWORKS 2014.
I see the differences in the engine version file in POST.EXE betwen HSMWORKS 2012 and HSMWORKS 2014. I suspect this file POST.EXE is not work properly!
Do you thing a license file don't work properly on this version?
Message 10 of 16
If your license is valid till 2019 you can try this version: http://www.hsmworks.com/files/hsmworks2016/HSMWorks2016-R4.41148-x64.exe
That is a HSMWorks 2016, and that works for SolidWorks 2014.
Laurens Wijnschenk
3DTechDraw
René for Legend.
Message 11 of 16
OK! I will try it.
Thanks for now! 🙂
Message 12 of 16
mcarver
pavlinbg
I do not think it is a license issue.  I would like to see your post and take a look at that.  If you could upload your post file, I can look through it.  It looks like it should be the below file.
"C:\Program Files\HSMWorks\posts\FANUC (RAIS M400) FINISH.cps"(copied from your post showing the errors.)
Message 13 of 16
@mcarver wrote:
pavlinbg
 onCorruption() is a post processor engine function that you cannot find in the post.
So it can't be the post processor itself.
It could be the installation or the licensing.
Laurens Wijnschenk
3DTechDraw
René for Legend.
Message 14 of 16
Exactly!
I thing the problem is in POST.EXE file (C:\Program Files\HSMWorks\post.exe)! This file don't work properly.
Message 15 of 16
Also with the 2016 version?
Laurens Wijnschenk
3DTechDraw
René for Legend.
Message 16 of 16
Hello!
Today I tried HSMWORKS 2016 R4.41148, which advise me and now works 100% perfect! Smiley Happy
I knewed, that the problem is in the post engine version POST.EXE! Now the newer post engine version 4.2.1.41078 in HSMWORKS 2016 works very fine!
No error massage and no fail posting!
I must treat you a beer! Smiley Very Happy
Thank you very much!!!
