Fanuc mill post expanded tapping cycle
I need to modify a generic fanuc mill post to post out tapping cycle in point to point code any help would be greatly appreciated I will attach the post I am using and the code I need it to output thanks.
andrea.amilo
Hello @Anonymous ,
I've tried to modify your fanuc postprocessor to expand the tapping cycle.
You can try to add the highlighted code lines (from 1935 to 1940) in onCyclePoint function:
Moreover you have to add lines 2508 and 2510 (highlighted) in onCycleEnd function:
Please test it carefully and let me know.
Andrea Amilo
Senior Technical Consultant
Autodesk Knowledge Network | Fusion 360 Webinars | Autodesk Make
