Fanuc A 4th axis
Fanuc A 4th axis
CNCfacile
Fanuc A 4th axis
CNCfacile
In the post processor library, the Fanuc inverse time has been deprecated. Someone can help me to set correctly the Fanuc generic post for A inverse time 4th axis.
Thank you in advance
Arun.rs
HI @CNCfacile
You can set the machine configuration in 'Setup' tab and select 'Feedrate method' as 'Inverse time'
Regards
If my post answers your question, please click the 'Accept Solution' button. This helps everyone find answers more quickly!
Arun.RS
Senior Technology Consultant
CNCfacile
I try it, but the Fanuc post seems do not work properly
CNCfacile
Thanks, Arun for your reply!
In the picture attached, you can see the kinematics setup that I have done. I have used the generic post Fanuc 44035.
As you can see in the second picture the nc code produces G00 A0 in the first drill and in the second drill should produce a G00 A90, but is not present any A axis movement.
AchimN
Hello @CNCfacile ,
into the postprocessor you need to change the setting "useTiltedWorkplane" to false as shown in the screenshot below.
Achim.N
Principal Technology Consultant
CNCfacile
Great Arun!
It works
Thank you very much
