I am looking for help creating a post process for my CNC, EZ-router. I have a post processor for Aspire by Vectric which I understand how to change but not the once needed for Autodesk. I've attached the PostP (changed .pp file to .txt so it would upload) that I use for Vectric if someone could help me or guide me, that would be great. Thanks.
Looking at the post you attached, the best post to start with would be the generic MACH 3 one included with HSM. Have you tested this yet? If not, please post out some code and mark up any changes / modifications that are needed
I have been into the same situation as you are in as I was also in the search of the same query. Then with my own research, I found the option in the Router settings that helped me to find out the solution of the post process.
Did you ever resolve this? I have a ez router with mach 3, we have been using the mach 3 post processor in fusion, but have had lots of issues with the z and rapid movement and when I asked ez router they said we needed a new post processor for mach 3???
