Export CNC File to VS Code - Error: Autodesk HSM Post Processor extension not found
joeymorgans
joeymorgans
I am trying to do some post edits whilst comparing my actual program next to the post I am using with the Autodesk Fusion Post Processor Utility. But when I use the 'export CNC File to VS code' post, I get an error:
Anyone have any ideas I could try to fix it?
Interestingly I am able to run it successfully with the pre-generated programs that come with the plugin:
Any help much appreciated!
Joe
AchimN
Hi @joeymorgans
i assume you are using an old version of the CNC file exporter postprocessor.
Can you please try using the latest version which you can find here?
https://cam.autodesk.com/hsmposts?p=export_cnc_file_to_vs_code
Achim.N
Principal Technology Consultant
joeymorgans
Wow, that was a simple fix. Thanks so much for your help!
