Error on post command in Visual Studios Code
reeltime273
reeltime273
Hello All,
Looking for some guidance utilizing the VSC post editor for Fusion, I receive this error "Cannot read properties of undefined (reading 'document') when selecting this command.  (Path: Explorer/CNC Selector/Drilling/Rapid out.cnc) this happens on every command not just the path above.
I have downloaded the entire Autodesk CAM Post Processor Guide 02/02/24, read it  but seems like I'm still missing a step?  I'm currently utilizing the standard MACH 3 Mill post processor from the Autodesk Post Library and would like to had some information to this post, like a header with details and a time stamp.  I have modified two (2) other post processors utilizing notepad with ease but struggling with VSC, and started out utilizing notepad when I started out originally with Fusion, which has been only a short time ago.     I believe I have the needed extensions but not 100% positive.    I have included a few sample files, please let me know what else I need to provide.   Any assistance is greatly appreciated.
Known Working File:
(COVER - INDICATOR SLOT)
(T2 D=0.5 CR=0. - ZMIN=-0.27 - FLAT END MILL)
G90 G94 G91.1 G40 G49 G17
G20
(WHEN USING FUSION 360 FOR PERSONAL USE, THE FEEDRATE OF)
(RAPID MOVES IS REDUCED TO MATCH THE FEEDRATE OF CUTTING)
(MOVES, WHICH CAN INCREASE MACHINING TIME. UNRESTRICTED RAPID)
(MOVES ARE AVAILABLE WITH A FUSION 360 SUBSCRIPTION.)
G28 G91 Z0.
G90
(SLOT2)
T2 M6
S1146 M3
G17 G90 G94
G54
M8
G0 X8.7917 Y2.31
G43 Z2.15 H2
G1 Z0.2 F10.4
Z0.1 F3.5
X4.2917 Z0.0753 F10.4
X8.7917 Z0.0507
X4.2917 Z0.026
X8.7917 Z0.0013
X4.2917 Z-0.0233
X8.7917 Z-0.048
X4.2917 Z-0.0727
X8.7917 Z-0.0973
X4.2917 Z-0.122
X8.7917 Z-0.1467
X4.2917 Z-0.1713
X8.7917 Z-0.196
X4.2917 Z-0.2207
X8.7917 Z-0.2453
X4.2917 Z-0.27
X8.7917
Z2.15
M9
M5
G28 G91 Z0.
G90
G28 G91 X0. Y0.
G90
M30
Thanks, Mark
serge.quiblier
Hi @reeltime273
your issue is probably close or simular to that one:
Solved: Post Utility Error - Autodesk Community - Fusion
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
reeltime273
Thanks for your response, however it did not resolve my issue.
serge.quiblier
Hello @reeltime273
the only extension required is the Autodesk Fusion Post Processor Utility.
Maybe the extension cannot find the post.exe executable.
Go to the edit field show below (A), then press the F1 key
In the field enter "change" to filter the commands supported by the running extension(s), and click on the command indicated by the B arrow.
A tip dialog will appear in the bottom right corner of VSCode editor. Click on the browse button in that dialog
then navigate to an easy to find folder:   😮
The name of the part indicated by (A) may change, depending on the Fusion version installed.
Then you can try again to post with the VSCode extension.
Regards.
Serge.Q
cam.autodesk.com
korogod.vl
Observer
Observer
This error can also occur if the version of post.exe is lower than the version of the postprocessor. The postprocessor may use functions that are not yet known to post.exe. To fix the error, you need to update the software.
