Emco Maier Compact 6p 120p lathe post processor including results
DaneelSE
Message 1 of 41
DaneelSE
Welcome to my second post processor project.
The Machine:
Emco Maier Compact 6p sometimes called Compact 6 CNC P or Compact 120p
The controller is an old TM01, so beware if your machine has a more modern TM02
My lathe's controller software revision is:
AC03.02/DC03.05
Some basic facts about the machine:
Working area
  • Swing over bed 180mm
  • Swing over cross slide 75mm
  • Max length between centers 180mm
  • Max diameter of workpiece 90mm
Main spindle
  • Through hole 21mm
  • Speed Range 80 - 4000 rpm
  • Manual chuck 80 / 85mm
  • Pneumatic power Chuck (without through hole)
  • Pneumatically operated tail stock
Automatic tool turret
  • 4 external tool holders (12mm shank)
  • 4 internal tool holders (16mm bore)
Main drive
  • 2 kW DC motor
Feed motors
  • Feed 1-1200 mm/min
  • Resolution 0.001 mm
  • Feed Power 2000 N
  • Rapid traverse 1200 mm/min
As the new forum don't permit editing of posts (I think) the updates will be below newer posts. A useful status update should have a summary of:
What's been tested, the result, suggestions or questions on how to proceed and maybe a attached file of the success, disaster and or a new post processor file.
At the moment the postprocessor is in early development and can't be used.
What is working (afaik):
  • Program header
  • Formatting of code (NXXXX<space><space>G-code)
  • Linear interpolations
What is missing or not working:
  • Tool change, Need some type sequence here, maybe M00 then move to safe position, make tool change and force new G00 to entry position
  • Ending of program move to safe position, reset offsets and turn off spindle
  • Drilling cycle
  • Threading cycle
  • More cycles?
  • Update the description in the post
Replies (40)
Message 41 of 41
DaneelSE
I still haven't tested Mayr version, sorry. As far as I remember it only works for lathes set up for radius programming, but that shouldn't be to hard to fix. I have done a few parts on my lathe but nothing advanced.
I did have a look at the threading cycles and fixed a couple of bugs but havent tested the new code, however we still have the acceleration distance not being taken care of in threading. I think this needs to be handled for both the G33 and G85 case.
I had a look at the diagrams found in the ET120 manuals.
A on the Y-axis is the needed distance to accelerate to get a properly formed thread for different pitch and spindle speeds.
I took a few points from the diagram above and using some accelerations formulas came up with this expression for the needed distance:
A=(F*n/60)^2/(2*a)+A0, where F is the threadpitch (mm) and n spindle speed (rpm), A0 is some sort of safety margin (mm), and A the recommended value.
The values a=134.97 A0=2.447 gives a very good fit to the data, realistically a=130 and A0=2.5 works as well. So now the question is, why do we need the 2.5 at all?
That's all I have for today.
