Can someone here help me to modify C axis values in fanuc mill-turn post processor? The condition right now the values of C axis is combine between + degree and - degree. So the direction of C axis CCW and CW. I would like to make the direction of C axis in one direction only ( + values degree). The picture show the detail.
Many thanks
Many thanks
The machine should just go the shortest way.
So it shouldn't matter in the actual move.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
It should be like that, but unfortunately the machine movement (c axis rotation, move in CW (+), and reverse CCW (-). so it wasting time, and that's why I would like to modify c axis become one direction (+ value only).
It's not the time I would be worried about in your case. The speed of the C-Axis is very high.
I would be more worried about the milling. If it does this in the drilling cycle it probably also does this in the milling which could be a bigger problem.
Laurens Wijnschenk
3DTechDraw
René for Legend.
